Question about Sony Handycam DCR-TRV350 Digital Camcorder
I need a charger and a power cord. - Sony Handycam DCR-TRV350 Digital Camcorder
  • 35 Answers
The charger is @ http://www.ebuybatteries.com/product/battery_chargers/Sony/Sony-NP-FM50-AC-charger.htm , it is an external battery charger, not a power cord.
Posted on Jul 13, 2010
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Need new charger
Norelco g370 charger power cord
Norelco 4203-035-78420
ac adapter charging cord for all in 1 grooming system norelco g370 power cord replacement parts.
Jul 15, 2015 | Norelco Philips G370 All-in-1 Grooming...
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
The charger does not seem to be working. No lights come on when we plug in in.
Make sure that the wall outlet is operational. Try replacing the power cord to the charger to see if that will fix the problem. It is the same power cord used to power most desktop computers. Take the cord with you to an electronics store to ensure you have a good match, they cost less than $20, keep your reciept just in case you need to return it. Plug that in to the charger (if it will fit), turn on the charger's power switch and see if you get any lights on the charger. If not, most likely the charger unit has been damaged and will need to be replaced, $275.00.
Oct 29, 2010 | NRS Hoveround MPV 5 - Used Power...
How do I change the fuse on a hoveround charger?
There are no serviceable parts inside the charger device to my knowledge, the whole charger will need to be replaced. One trick to try first: If the problem is with power, try using your desktop PC power cord to power the charger. If it will fit, plug it in to the charger then into the wall and turn it on and see if you get a light. If so, it was just the power cord, if not, the charger is most likely dead and needs to be replaced- $275.00.
Oct 26, 2010 | Health & Beauty
Need power cords and phone chargers
They are available on eBay for quite cheap, I just did a quick search and they can be had for under $10 including shipping. Depends on the exact model number of your unit, there wasn't a huge selection.
Jan 08, 2009 | Durabrand PDV-709
Battery charger
My Nikon MH-53 takes the same lead as my Panasonic charger so I think the problem is in your charger.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Sony Handycam DCR-TRV350 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
