Question about Ryobi Saws
Made in USA push action with stop button print on switch LUCERNE USA 10212 250 V 16/8A saw around 10 years old
  • 4 Answers
Same switch as used in Wen #6014 electric chain saw - anyone find a replacement
Posted on Nov 23, 2010
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Lucerne usa switch
First, we need to know whaqt you mean by a "Lucerne Use Switch".
Oct 23, 2013 | 1990 Ford F150
I have a Task Force 10" band saw, model # 90181.
for the tires, I asked in another forum and this is what I found:
fortyfinge user_offline.gif Join Date: Sep 2004 Location: USA Posts: 2 reputation_pos.gif way easier, way cheaper masking tape. Just plain white masking tape. About 8-10 wraps around the circumference of your wheel. I tried this about 15 years ago as a stop gap method while waiting for the new rubber ones I'd ordered to arrive. The new rubber was a pain to install and only lasted a couple of years under daily use.
Jun 13, 2011 | Saws
I have an old delta tablesaw. It has a start and stop button. When the start button is pushed it used to start and run - now it only runs while the button is pushed. What is the problem? and how do I...
sounds like the on/off switch is bad. replace the switch with a switch that is of the proper voltage and rating value. a good place to find a switch is at your local hardware/industrial tool store. ( also try and find a switch at a industrial tool repair shop ).
c...
Jan 19, 2011 | Powermatic 1720305K 14" 7.5 HP 3 PH Model...
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full...
most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Aug 02, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How to reset a 740 power shop radial arm saw. Saw stopped during a cut. Breaker is good. Power source is good. Can find the reset button.
Hi Welby:
My saw is not a DeWalt, but the procedure should be similar.
First, WORK SAFE! UNPLUG THE SAW.
Now you can explore without the prospect of having it bite you.
Here are the things I would do:
1) Set the On/Off switch to OFF
2) Have a look at the motor. There should be RED (typical) reset button. When you find it give it a good solid push.
3) Check to make sure the On/Off switch is still OFF.
4) Plug in the saw.
5) Try turning it on.
If it does not work, I would unplug it and use a continuity meter to start checking the various components, especially the On/Off switch. If it has failed and you can't get a replacement you could
do as I have with an old Craftsman. It is 110 or 220, and has only been used on 110. Half of the switch terminals had arced over 40 years of use, so I just re-wired the switch to use the other terminals but still be 110. .
Feb 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
I have an elu flip saw that works as atable saw but not as a drop saw is there a wiring diagram so i might trace through the fault
there is a cable that runs from in behind the drive belt and around and under to the main switch block . because of the flipping action it can open circuit . youllhave to check it with multi meter . good luck old but good machine.
Nov 15, 2009 | Saws
Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Nov 02, 2009 | Saws
Saws Logo
1,330 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
