I was house sitting at my buddys last week i brought my laptop over hooked up to his wirless router its a netgear router and now hes home trying to get on and the password i wrote down wont let him connect to his internet how do we fix that
    Guru:
  • 830 Answers
I believe this question posted twice for some reason.
Posted on Oct 08, 2009
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
Had my netgear router for months now and not had a
Solution to intermittent wireless connection is change the wireless channel of the router. Usually the default channel is 6 which is prone to interference. You may try channels 11 and 1. They are the next strongest channel of the router. Try to reset the router first.
Jun 06, 2009 | NetGear DG834G Router
Internet conection via linksys gateway through netgear router
Not totally for sure but i am myself running linksys. if its a new pc you must first configure your settings in order to hook up it up. on ur pc you should have networks first try running a land line to it and see if you can connect if you have multiple routers its very easy to make a mistake with the wiring.
Apr 22, 2009 | Computers & Internet
Netgear Wireless Router Problems
Use the process of elmination, disconnect Vontage, does the problem go away? If no then look at the modem (cable or dsl).
Hint! If you have a cable modem, make sure all cable connections are tight from the outside of the house, to every TV, and from the wall to the cable modem. Use plyers to tighten all of them.
Jan 21, 2009 | NetGear WGT624 Wireless Router
How to find my key code to hook up laptop
Go to a machine that is on the network and login to your router. www.routerlogin.com comes to mind. The default username and password is admin and password. If you've changed the password away from it, you'll have to use that password instead.
Once you get there, you should open up the Netgear Smart Wizard with blue tabs down the side. The second category is Wirelss Settings. When you click on that, it displays a network name (SSID), a security type, and a wirless key that you have set.
For example, mine is set to WEP 64bit Automatic and I have a simple 1011121314 key in key 1.
My house is also 1 of 4 in a cul-de-sac :-)
Carl
Oct 12, 2008 | NetGear WGR614 Router
New Router and Laptop no wirless connection after 4 hrs .
There are a couple of ways to go on this one..first plug into the router with a netwrok cable, NOT via wireless.
If you have just opened the box on the netgear router you would need to configure some basic settings such as the SSID (name of the router) the country the router is in and maybe some type of security settings...often this cannot be done via a wireless connection at first, you must connect your laptop's netowrk port to a touter port on the rear of the Netgear. Open I.E. and navigate to something like http://192.168.0.1 (look on the sticker on the botton of the Netgear) setup the basics then try your wireless link using the settings you programmed.
May 10, 2008 | NetGear WGR614 Wireless Router
Netgear Wireless Router WGR614v6
so chitodel click on start button
then CONTROL PANEL>NETWORK CONNECTIONS> right click WIRLESS CONNECTION>PROPERTIES>in GENERAL tab click on INTERNET PROTOCOL>PROPERTIES and then click OBTAIN AN IP ADDRESS & OBTAIN DNS SERVER ADDRESS AT LAST CLICK O.K. this will help u try it now..........................
GOOD LUCK.
Feb 06, 2008 | NetGear WGR614 Wireless Router
My 3 different mac laptops with airport can't connect to my wirless
Sounds like you might be accidentally connecting to a neighbour's network instead of your own. You need to go into your wireless settings on each laptop and tell them to connect to your own network.
Jan 16, 2008 | NetGear Super G WGT624SC Router...
Wirless Router
If you're able to print from main PC ,then run printer configuration disk (which you've used to configure printer on main PC) on your Laptop , Provide static IP address to printer & laptop,within same domain(like you can use class c IP address 192.168.1.x (x=2 - 251) & subnet ask 255.255.255.0 ,MAKE SURE THAT IP ADDRESS SHOULD BE DIFFERENT FROM YOUR MAIN PC ELSE THEY'LL RESULT INTO CLASH) .After that try to make a test print. If it doesn't work then check whether ports you're suing for printing are open in your Firewall inside laptop (If there is Firewall), Also win XP sp-2 Home adition has built in Firewall try to print after disabling it.
Jan 07, 2008 | NetGear DG834G Router
Change router locaation
do factory reset of configuration settings then log in with the routers default credentials. then change settings to your liking with one exception: DO NOT USE WEP!!!!! At a minimum use WPA 1 personal (with MAC filtering if you know how.) WEP can be hacked in less than 5 minutes.
Dec 13, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
