Question about TDK DA-3826 2-Disc CD Recorder
Recording Can I record directly from a amp? Also how long will it take to burn (finalize) to CD (real time or at a faster rate)?
  • 112 Answers
Yes it will record from the tape outputs of an amp. It finalizes at double speed which in this units case is approx. 2 minutes.
Posted on Jan 15, 2008
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Do I just push finalize to finish the burning of the cd?
after you've finished recording press 'finalize' the recorder will then get ready for finalizing and then a countdown time will appear in the display eg '1:20' once this appears press 'play' and the recorder will start to finalize and the digits will count down to zero, once this has finished, your disc is finalized.
Feb 01, 2010 | Pioneer PD-R555RW CD Recorder
It wont record on 16xdvd+r discs? what is the properdisc
  • Media Type that the unit will play CD , DVD , CD-R , SVCD , CD-RW , DVD+R , DVD-R , DVD+RW , DVD-RW , DVD-ROM , Video CD
  • Media Format PAL , NTSC
  • Recordable Media DVD+R , DVD+RW only.. It will not record on the more expensive and compatible DVD-R, DVD-RW.
  • I recommend burning at a slower speed such as 2.4X, 4X or at most 8X.
  • I had similar issues resulting in many "coasters" for drinks burning at a faster rate even with my computer. Although some disks are designed to burn at a faster rate, software and components sometimes cannot keep up resulting in wasted money and time.
  • It may also be the media (manufacturer of disks). No matter which DVR or Burner you may have certain hardware schemes do not like certain media. It is a trial and error process. Just make sure the store has a return policy for the disks if they don't work. I have never had a problem returning disks to Staples that did not work.
I hope this helps and good luck.
Oct 27, 2009 | Gateway AR-230 DVD Recorder
any speed is fine.the slower the speed on the cd..say 8x will take much longer to burn something onto then say a 48x..the faster the cd is the faster the cd burns unless your cd writer says 8x then that is the fastest it will burn 8x vrs 48x..48x is faster You can buy new burners for around $30.00 and they are 52x speed nowadays .
Aug 12, 2009 | RCA CDRW120 2-Disc CD Recorder
CD's won't play in other machines
Your problem is an easy need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
Timing of Mastering and burning final copy to CD
I don't use my Tascam to create CDs for exactly the reasons you are asking about. I do a bounce mix to a couple of tracks and then export via usb to a PC for finalizing and CD creation there.
To answer your questions, you do always need to create a master first for each sermon on the DP-02 before you can burn it to a CD. You also have to finalize the CD to play it on other players.
Mastering as well occurs in real time, so it does take 60 minutes to create a master for a 60 minute recording.
As I don't burn from my Tascam, I didn't realize the burn time was so long though. I would have expected that to be faster for sure. I know my old 2488 MkI is supposed to burn at 4x and I believe the MkII burns at 8x. The DP-02 is newer than both and I would assume it would burn even faster.
Anyway, as I said you might wish to go the PC route. That way you can export the tracks without having to master them and burn them from the PC to CD at up to 40x (depending on the speed of your PC's burner).
Hope this helps.
Jan 06, 2009 | Tascam DP01 All-In-One Recording Package...
Hhb cd recorder
at the time of burning to avoid this problem select multisession option in nero:
Sep 29, 2008 | HHB CDR850 CD Recorder
Que! USB 2.0 -can't get it to burn cd
I am trying to burn data files and it gives me: The option to continue an existing CD is disabled, because you have selected the image recorder. Select you real recorder by using the menu command "CD Recorder" 'choose recorder' to enable this feature.
On the menu, I clicked on Recorder, then choose recorder and Image Recorder is the only one lister.
Please advise...john
Mar 07, 2008 | QPS Que! USB 2.0 Drive CD-RW Burner
CD isn't finalized
no that means that the cd wasnt fully burned before ejected and you can still finalize it if you put it back in the device that started burning it it will do it
Dec 10, 2007 | Denon CDR-M30 CD Recorder
TDK DA-3826 2-Disc CD Recorder Logo
42 people viewed this question
Top TDK Audio Players & Recorders Experts
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
