Bose fuse - Audio Players & Recorders
  • walsher Oct 08, 2009
    is the power supply board in the tower, or the disc changer
  • 3,741 Answers
You can get the fuse from the link below.just click the link directly. http://www.bose.com/controller?url=/shop_online/speakers/portable_amplification_systems/accessories/l1_fusekit_acc.jsp ----------- the fuse is located on the the power supply board. --------------- This will help. Thanks please keep updated.please do rate the solutionif helped.thank you for using fixya.
Posted on Oct 08, 2009
  • charlymonty Oct 08, 2009
    the power supply board is in the tower.its where you connect the main power cord wire for the unit.
If i change the transformer of bose wave from 110 volts to 240 volts would i change the fuse
No, because the internal fuse protects the circuit after the transformer. The fuse should be marked anyway. If it says 110 volts, 5 watts, then you would need to swap it for 220 volts 5 watts.
You can of course ask Bose direct.
Better Sound Through Research Bose Worldwide
Aug 16, 2017 | Bose Audio Players & Recorders
Bose repair
Does not seem very complex. I think it is because of the broken fuse. Simply Open the back part of Bose companion 5. The Circuit board attached to the back part is basically for the Audio output socket, Control pod Connector and Power supply connector. on the Left hand side of the board you will find a fuse soldered with the board. most probably that fuse is broken. replace the fuse if broken or just connect both end of the fuse with thin wire (temporary) to check. Hope it helps.
I am outta home or else i could have added an image for you. maybe tomorrow.
Thanks
Jun 23, 2014 | Bose Companion 5 Multimedia Speaker System...
Bose l1
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
You might also want to consider posting the question in a category other than "Calculators."
Thank you for using FixYa.
Dec 14, 2011 | Office Equipment & Supplies
Hello........ looking for a schematic for Bose 501 series 3 speakers. I need to replace the fuse in line with the tweeters.... its blown & does not have a value on it (unmarked, quick blow, twin lead,...
Did you find a solution? Dunno if it's much help, but I just today picked up some 501s - Series I I think - ugly heavy brown material grilles - but with a manual! No fuses in these, but booklet recommends installing your own in-line fuse holders (!?). Specifies a BUSS AGC-3 fuse for amps under 50wpc; or a MDL-2 fuse for amps over 50 wpc. Can be placed is series with either or the two signal wires. Very strange.... Robin
May 14, 2011 | Bose 501V Speaker
Where is the fuse for bose wave radio
Upon opening the Bose Wave radio.. 4 screws only from the bottom. The fuse is located at the top side of the PCB. It is a small fuse. Kindly inform me if you need a picture. I am repairing one now
Aug 07, 2009 | Bose Wave Radio
BOSE RADIO
The line fuse for these sets is inside the radio on a printed circuit board. NOTE: for your safety, disconnect the radio from its power source before you open the case and poke around inside. The best way to check the fuse is with an ohm meter, but you can probably check it visually using a strong flashlight. There should be a wire filament running the length of the fuse. If it's intact, so is the fuse. If it's broken or not visible at all, the fuse is "blown" and needs to be replaced. If the fuse checks out ok, the power transformert is likely bad -- a problem that these sets are notorious for. Bose will charge you $100 for the transformer repair (unless the set is still under warranty), and having it done is strictly a matter of personal choice. My choice would be to sell the Bose on eBay as a "tech special" and pick up one of the newer HD radios. They offer much better sound at a much lower price.
Bill B.
May 14, 2009 | Bose Wave Radio
120v Bose Wave Radio/CD player plugged into 240V outlet
there is a fuse inside but after changing the fuse if it still dont work the rectifier could be bad.
Jan 13, 2009 | Bose Wave Radio
Bose radio
There's a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Dec 18, 2008 | Bose Wave Radio
Replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Apr 09, 2008 | Bose Wave Radio
 Grubhead
Grubhead
