Question about NetGear Computers & Internet
I was house sitting at my buddys last week i brought my laptop over hooked up to his wirless router its a netgear router and now hes home trying to get on and the password i wrote down wont let him connect to his internet how do we fix that
  • 3 more comments
  • airmenbilder Oct 08, 2009
    ok go to that site and put admin as the name and password as the password?
    just want another oppinon
    ok hes trying it um im at home we were talking threw text message so il find out if it worked
    where do i find the username and password is that what i wrote down when it made me set up the account?
    thank you much
    Guru:
  • 830 Answers
The quickest fix would be to reset the router. There is a little button the size of a pin located in the back of the router. Get a small paperclip and press it in for 15 seconds. Release and reconnect the router. The information will need to be setup as this erases all information (passwords, etc) from the router. In order to have a flawless reset, visit neatgear.com and download the software needed to reinstall easily.
Another fix (not as quick) would be to type in 192.168.1.1 into the address bar. Enter the username and main router password. Click on wireless security and change the password. You need the router username and password for this fix.
Posted on Oct 08, 2009
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Oct 08, 2009
    The password and username for the router are the ones you created when you set up the router. You may have also changed the default password (to 192.168.1.1) while setting the router up so the default may not work. Two seperate passwords.
  • 10,515 Answers
For Netgear, enter http://www.routerlogin.net in the address box of the IE browser and admin as Name and password as Password. Then see Wireless tab and find security info, or change.
If the above fails, you could reset the Netgear router by using a staple on the small hole at the back for 20 seconds. If you take that step, you will have to match settings for all wireless units.
Usually default password is password.
To exactly know, how you need to set router, follow the below link :-
http://kb.netgear.com/app/answers/detail/a_id/112
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Oct 08, 2009
    Thanks for your response!!
    You may consult other experts. We are fixing internet connection. Had been this a washing machine, and you need to replace a part, there is always a possibility for consultation.
    Anyway, yes you need to put the same. If that not work, Reset and then again trying to login onto router. Follow the link, in case if you want to set the router settings.
    Hope i helped you.
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
Had my netgear router for months now and not had a
Solution to intermittent wireless connection is change the wireless channel of the router. Usually the default channel is 6 which is prone to interference. You may try channels 11 and 1. They are the next strongest channel of the router. Try to reset the router first.
Jun 06, 2009 | NetGear DG834G Router
Internet conection via linksys gateway through netgear router
Not totally for sure but i am myself running linksys. if its a new pc you must first configure your settings in order to hook up it up. on ur pc you should have networks first try running a land line to it and see if you can connect if you have multiple routers its very easy to make a mistake with the wiring.
Apr 22, 2009 | Computers & Internet
Netgear Wireless Router Problems
Use the process of elmination, disconnect Vontage, does the problem go away? If no then look at the modem (cable or dsl).
Hint! If you have a cable modem, make sure all cable connections are tight from the outside of the house, to every TV, and from the wall to the cable modem. Use plyers to tighten all of them.
Jan 21, 2009 | NetGear WGT624 Wireless Router
How to find my key code to hook up laptop
Go to a machine that is on the network and login to your router. www.routerlogin.com comes to mind. The default username and password is admin and password. If you've changed the password away from it, you'll have to use that password instead.
Once you get there, you should open up the Netgear Smart Wizard with blue tabs down the side. The second category is Wirelss Settings. When you click on that, it displays a network name (SSID), a security type, and a wirless key that you have set.
For example, mine is set to WEP 64bit Automatic and I have a simple 1011121314 key in key 1.
My house is also 1 of 4 in a cul-de-sac :-)
Carl
Oct 12, 2008 | NetGear WGR614 Router
New Router and Laptop no wirless connection after 4 hrs .
There are a couple of ways to go on this one..first plug into the router with a netwrok cable, NOT via wireless.
If you have just opened the box on the netgear router you would need to configure some basic settings such as the SSID (name of the router) the country the router is in and maybe some type of security settings...often this cannot be done via a wireless connection at first, you must connect your laptop's netowrk port to a touter port on the rear of the Netgear. Open I.E. and navigate to something like http://192.168.0.1 (look on the sticker on the botton of the Netgear) setup the basics then try your wireless link using the settings you programmed.
May 10, 2008 | NetGear WGR614 Wireless Router
Netgear Wireless Router WGR614v6
so chitodel click on start button
then CONTROL PANEL>NETWORK CONNECTIONS> right click WIRLESS CONNECTION>PROPERTIES>in GENERAL tab click on INTERNET PROTOCOL>PROPERTIES and then click OBTAIN AN IP ADDRESS & OBTAIN DNS SERVER ADDRESS AT LAST CLICK O.K. this will help u try it now..........................
GOOD LUCK.
Feb 06, 2008 | NetGear WGR614 Wireless Router
My 3 different mac laptops with airport can't connect to my wirless
Sounds like you might be accidentally connecting to a neighbour's network instead of your own. You need to go into your wireless settings on each laptop and tell them to connect to your own network.
Jan 16, 2008 | NetGear Super G WGT624SC Router...
Wirless Router
If you're able to print from main PC ,then run printer configuration disk (which you've used to configure printer on main PC) on your Laptop , Provide static IP address to printer & laptop,within same domain(like you can use class c IP address 192.168.1.x (x=2 - 251) & subnet ask 255.255.255.0 ,MAKE SURE THAT IP ADDRESS SHOULD BE DIFFERENT FROM YOUR MAIN PC ELSE THEY'LL RESULT INTO CLASH) .After that try to make a test print. If it doesn't work then check whether ports you're suing for printing are open in your Firewall inside laptop (If there is Firewall), Also win XP sp-2 Home adition has built in Firewall try to print after disabling it.
Jan 07, 2008 | NetGear DG834G Router
Change router locaation
do factory reset of configuration settings then log in with the routers default credentials. then change settings to your liking with one exception: DO NOT USE WEP!!!!! At a minimum use WPA 1 personal (with MAC filtering if you know how.) WEP can be hacked in less than 5 minutes.
Dec 13, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
