Question about RIM BlackBerry 7100G Smartphone
Can't send text messages
Whenever I try to compose a txt message it automatically calls!
  • 555 Answers
Greetings...
Regarding on your problem, please try to make a hard reboot of your phone and then take out your battery then wait up to 5 mins then installed the phone battery back then start your phone then try to send a sms.
Thanks
Posted on Oct 08, 2009
Everytime I try text my phone says 'can't send' however I can recieve messages?
Can you send txt msgs before? Please try calling if it iw working. If you can't call too, please call your service provider.
Sep 03, 2012 | Nokia Lumia 800
Please help i cant send text messages from my motorizr z3 but i can still receive text messages, when i try to reply or compose a message it says please try again later....
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 01, 2010 | Cell Phones
I can receive txt msg and make and receive calls on my nokia e65 but cannot send txt msg. Why would this be?
hi....
I think when you send text message it says message failed...right..???
This is because there is option in your mobile called as message service centre number.please check weather this number is correct.Call your service provider and you can get this number.
And also there is an option called as reply via same message centre please put this to 'NO'. now you can send messages
To go to this options please check follow these steps....
1.open 'menu'
2.open 'messages'
3.Go to 'message settings'
4.in that open 'text message'
5.there is an option called as 'message centre',please entre your new message centre number and save it. set this as your message centre
6.Check the option 'reply via same centre' and please put it to 'NO'
Thanx
Jul 17, 2010 | Nokia e65 Cellular Phone
Can't send a Text Msg on my Razor
go to create message then select the format:
New Short Message
New MMS Message
MMS Templates
Send to online album.
Start with the first option,then you do a little more exploring with the different formats.
Mar 03, 2009 | Motorola Mobility RAZR V3
Cannot send text messages
ok Go to Menu>Messaging>Message Settings>Text Messages>Message Centers>message center>Save.
and then try to text again
i had the same problem but then i did that and i then i could txt
Feb 26, 2009 | Nokia 5200 Cellular Phone
I can't send any message or recive
How can I use the messaging features on my Motorola phone? space.gif space.gif answer.gif To send a text message:
  • Enter your Message menu
  • Scroll to Create Message and Select
  • In the To: field, either enter a telephone number**, e-mail address**, or Browse your Phonebook, Received or Dialed Calls list.
  • Enter your message in the MSG: field
  • Select done when you have completed the To: and MSG: fields
  • Confirm that you would like to send the message now
Please note that text messaging is a service provided by your cellular service provider and you must subscribe to this service to have the capability to send text messages. Certain carriers may require alternate instructions.
**Please contact your carrier for further information on these services, and to ensure they support sending to both a telephone number and/or e-mail address.
To send a text message - Select Menu, Messages, Create Message, and then New TXT Msg
<a href=""http://motorola.custhelp.com/cgi-bin/motorola.cfg/php/enduser/std_adp.php?p_sid=Id42qGph&p_lva=4061&p_faqid=4064"" target=""_self"">To send a multimedia message -Select M, Messages, Create Message, and then New PIX Msg
To Insert Objects In Text Message while composing a text message - Select Menu, and then Insert
To use MMS Template open an MMS template with preloaded media - Select M, Messages, Create Message, and then PIX Templates
To read a new text or multimedia message that you have received - Press Read (Right Soft Key).
To Store Message Objects - Go to a multimedia message slide, or highlight an object in a letterand select Menu, and then Store
To send or create a quick note message - Select Menu, Messages, and then Quick Notes
To view sent messages - Select Menu, Messages, and then Outbox
To read received messages - Select Menu, Messages, and then Inbox
Tip: Press Menu to perform various operations on the message.
To view messages saved in drafts folder - Select Menu, Messages, and then Drafts
To delete all messages or only messages from the Outbox or drafts folder: Select Menu,; Messages, and then Cleanup Messages
Oct 22, 2008 | Motorola Mobility RAZR V3
Cant recieve text messages
Maybe you never activated the phone to receive txt messages. Call up sprint and activate incoming txt.
Apr 23, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Txt messages
Error message 38 means there was some type of problem with the number to which you were texting. When sending a text message, make sure you are sending the message to a ten-digit mobile number (assuming you are in the US). If you're sending a text message to an entry you've saved to your address book, make sure that you stored the number with area code in your address book.
If all of that checks out, or if you've had no problems texting to this exact number before, you will want to place a call to customer service with your wireless service provider. They can look at message logs within their network to see what happened and why the attempt failed.
good luck
c.j.
Mar 26, 2008 | Motorola Mobility RAZR V3x Cellular Phone
RAZR V3XX - sends my texts as MMS, rather than SMS...
I had this same problem and called Motorola for support. The solution is to clear text/mms message inbox and outbox. The default setting on my phone was to never clear the inbox but I changed that to remove messages when they are 10 days old, I have not experienced the problem since.
Nov 07, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Pls help with template problem
when you go "new message" in the messages menu it should give you an option of text message as well as multimedia message and other things. If the problem is when replying to messages it should automatically send in text format and if it doesn't then it should once you have sent some "text" messages from the "new message" option. Hope this helps :-)
Nov 05, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry 7100G Smartphone Logo
70 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
