Question about Dewalt Saws
I have a 36 volt recepicating saw. the handle is
I have a 36 volt recepicating saw. the handle is becoming loose. how do i tighen it up?
    Novelist:
  • 141 Answers
There may be an underlying problem inside the handle. Sometimes the little nubs where the screws anchor crack inside the handle and will just turn when you try to tighten or loosen the screw. If you cannot back off the screw from the handle the nub is more than likely broken off from the handle. If this is the case you should order a new handle set from dewalt. You can then remove all the screws and then the little nub with a set of locking pliers. You could try to super glue the small piece back to the handle but it will fail eventually. If you have any questions please post back.
Posted on Oct 13, 2009
How do i change the blade on a Bosch PFZ550E reciprocating saw? note it is completely different to the 500.
There is only an allenkey necessary( its most inside the machine tucked away ) partnr 37 until part 36 become some loose very simple principle.
Oct 06, 2016 | Bosch Saws
CAN i CHARGE A 36 VOLT BATTERY WITH A 24 VOLT CHARGER?
No of course not.
The charger has to be the same as the battery it is charging. On BIG batteries, it also has to have the power to handle the higher amps as well.
  • 36 Battery Charger Volts - 36 Battery Charger Volts - Deals! Ad · www.HomeGardenPro.com 36 Battery Charger Volts - Deals! Your Home, Your Style - Redefined.
    Handpicked Collections · Great Deals - Low Prices
  • 36 Volts Battery Charger ' Calibex.com Ad · www.Calibex.com/Electronics Cheap Prices and Huge Selection 36 Volts Battery Charger on Sale!
  • 36 volt battery charger in Batteries & Chargers ' eBay www.ebay.ca > Search > 36 volt battery charger Find 36 volt battery charger and 36 volt battery from a vast selection of Batteries & Chargers. Get great deals on eBay!
  • 36 Volt Battery Charger ' eBay ebay.com Find great deals on eBay for 36 Volt Battery Charger in Forklift Batteries and Chargers. Shop with confidence.
  • 36 Volt Battery Chargers ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Chargers in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Chargers - Electric Scooter Parts www.electricscooterparts.com/36vchargers.html 36 Volt Battery Chargers for Electric Scooter, Bicycle, Pocket Bikes, and Go-Karts. We have 36 Volt (36V) battery chargers in stock.
  • 36 Volt Battery Charger ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Charger in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Charger eBay
    Sep 20, 2016 | Health & Beauty
    Can't lock miter angle with slide handle
    There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
    Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
    HOW DO YOU UNLOCK THE ARM ON A DELTA MITER SAW 36-075, IT IS NOT A STAND BUT THE ARM ITSELF?
    Here is a link to an exploded parts diagram and instruction manual for that saw.
    Normally, all that is required is that you unscrew the handle and turn the table, then lock the handle in the desired position. But as with many older saws, the table may become jammed with dust and foreign objects and need to be cleaned and lubricated in order to work properly.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jul 23, 2011 | Delta 36-136 Universal Miter Table Saw...
    Echo cs-310....how to put chain on after it became lose....also how to tighen when it becomes loose.
    At the right side take out the panel that hide the bolt that has a large groove.When unbolt move froward the chain holder and tight the bolt but not too tight just go further until you can test it by hand making the chain to move freely but stable.Reverse the procedure.
    Post / thumbs / testimonial are welcome!
    Nov 12, 2010 | Echo CS310 14" Bar Length Fully Assembled...
    Rm2807 rv refrigerator gas works but the a/c is not working
    Check the 110 volt wire for flaws. Take a volt meter and check the recep that the fridge plugs into for power, should be 110 volts or so. +/- 10%. If you have power at the recep problem is in the fridge chord or circuit board fuse or circuit board. Also check the 110 volt breaker in the coach at the service panel.
    Mar 29, 2009 | Dometic RM2852 Refrigerator
    Need owner's manual for used Unisaw 36-812
    You can download one from the Dewalt service center. Click on this link and choose the saw that most closely matches your own:
    http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=36-812
    If you found this link to be helpful, please rate this response so I can become a trusted advisor. Enjoy your new saw!
    Mar 21, 2009 | Delta Saws
    Saws Logo
    241 people viewed this question
    Top Dewalt Saws Experts
    Parson's Repair...
    Parson's Repair...
    JOHN LAPIER
    Are you a Dewalt Saw Expert? Answer questions, earn points and help others
