Compaq proliant 5500 hangs on post led display shows pci configuration but goes no further
    Master:
    Sergeant:
  • 460 Answers
It is logic card problem of printer. so you can check it from service center.
Posted on Oct 08, 2009
Server no display when power on
Can you confirm that server fan is rotating or not when server power on. and which led glowing red when you power on server
Mar 15, 2014 | HP Compaq ProLiant ML350 G3 Server
Proliant server running Linux hangs at "attempting
I'd say the hard disk went bad. See if it'll boot from a live cd to copy your data off of the linux drive (if it's accessible at all).
Dec 30, 2010 | HP ProLiant ML370 G4 Server
Compaq ProLiant DL380 G2 boot error. Front panel led "Internal health" initially green, then goes red with 2 second beep alternating with 2 second off. All ram leds yellow - only two populated. ...
You can get all of the documentation here
Also, Judging that the LEDs are not corresponding with the servers actual status (processor LED), This server may have been taken apart and the wires to the status leds were incorrectly reconnected. I would look at the documentation for the motherboard and compare to the wiring diagram. The RAM May be an issue. Depends on whether the machine makes it past POST (Power On Self Test). If it does, The ram is fine. If not, I would inspect that beep code further. It probably has something to do with the memory. If the memory is malfunctioning, you will get no response from the machine other than beep codes and status leds. According to the documentation, the closest match for your beep code means this:
207-Memory Configuration Warning -
DIMM In Socket X does not have Primary Width of 4 and only supports standard ECC.
Advanced ECC does not function when mixing DIMMs with Primary Widths of x4 and x8.
Audible Beeps: 1 long, 1 short, or none
Possible Cause: Installed DIMMs have a primary width of x8.
Action: Install DIMMs that have a primary width of x4 if Advanced ECC memory support is required.
I hope this helps. Thank you for choosing fixya.com
Dec 03, 2010 | Compaq ProLiant DL380 Server
Ths screen displays ERROR,Expansion ROM not initialized-PCI network controller on Motherboard. Bus:04,Device:04,Function:00 how do i fix this? I am trying to install win 2003 server ,system not...
The ProLiant ML110 server with System BIOS Version 16 supports a total of eight IPL devices. Four IPL devices, such as the IDE controller and the floppy controller, are integrated, leaving support for four additional PCI IPL devices (i.e., PCI card plugged into PCI expansion slots); however, the ProLiant ML110 has five PCI expansion slots. Therefore, it is possible to configure the ProLiant ML110 with five PCI IPL devices (such as SCSI controllers or NICs) and exceed the limitation of System BIOS Version 16
The resolution to the problem is to update the System BIOS Version 17 which supports a total of nine IPL devices and five PCI IPL devices. Update the ProLiant ML110 server to System BIOS Version 17
i could not include the url for the download because you did not especify the generation of your server
but follow this link
1.select your server with the corresponding generation
2. select the operating system
3. from the download list select the bios update to a bootable usb or diskete
4.install the os
Oct 27, 2010 | HP ProLiant ML110 Server
Proliant 5500, installed configuration and OS w2k3 all operationa
What controller do you have? Have you tried running smart start that came with the system?
May 14, 2009 | Compaq ProLiant 5500 Server
No video at all on Compaq ProLiant 1850R
Do the server has an onboard Video disable the video in the BIOS setup insert another PCI Video card and check for the display , IF the PCI display is up then there could be a problem with Onboard card.
Nov 27, 2008 | HP Compaq ProLiant 1850R Server
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
29 people viewed this question
jasbo
jasbo
