Question about OKI C3100 Led Printer
Drum re-set Fuse ?
Oki C3200 Drum reset fuse . . . what value should I use?
  • jomer47 Mar 16, 2008
    reset drum agotado
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Is this still current?
Posted on Aug 19, 2008
OKI B410dn drum life
Every Oki B410d printer, Oki B410dn, Oki B430d, Oki B430dn, Oki B440dn, Oki MB460, Oki MB470, Oki MB480 are contacting the module of the Oki 43979002 drum and fuse with chip developed in the module imaging unit through joints being in the bottom part of a printer like in a photo. Eksploatacja Oki B410 pochodne drukarki reset kasowanie bbna
Jan 28, 2014 | Oki Electric Industry C8600n Led Printer
Oki b431 DRUM reset
hello good afternoon, friend u can give a hint of how I resouvo the problem of drum printer oki 431dn + b, pending
Jul 05, 2012 | Oki Electric Industry B431d Printer
Reset drum on oki c610
There's a small fuse in the drum that blows when it's first powered up after changing the drum. You can emulate a small fuse with an analog VOM set on Amps. With printer OFF, using a light wire like phone wire, connect the VOM to the drum terminals. When you power up, in a few seconds you'll see the VOM needle bounce one way or the other (doesn't matter). The moment you see that, pull the connection from the VOM. You've just impersonated a small fuse blowing. Here's an article on how to make that connection to the drum: http://www.fixya.com/support/t8952601-reset_drum_life_oki_c3400
Feb 17, 2012 | OKI Office Equipment & Supplies
How to reset drum for the oki B410DN
Most of the OKI printers have a fuse installed in the drum to do the reset. If you google the drum reset kit you can find the drum kits and fuses.
Jan 14, 2010 | Office Equipment & Supplies
How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Oct 07, 2009 | OKI C3400n Laser Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
I would like to reset the drum counter of my OKI 8800
You need to insert a 1/16A fuse into the drum and let printer blow it thus resetting the counter. Don't use fuses with the higher rate - they can easily blow your printer instead! Much more expencive that putchasing a new drum. By the way - 20k at continuous printing, meaning print jobs are as big as 100-200 pages each. The less pages per job the sooned drum life ends up.,
Mar 05, 2009 | OKI C8800dn Led Printer
Toner sensor problems
sensor window on the drum is closed - or the r/h side of the printer has a sensor that needs cleaning.
Dec 24, 2007 | OKI C3100 Led Printer
OKI C3100 Led Printer Logo
1,198 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
