Question about Sony Cyber-Shot DSC-T1 Digital Camera
Can't download pics
When I plug the usb port to the camera and the pc the camera sayw switch on menu, I switch on menu and it says usb connect. The pc does not download or even give the option to download...I've tried on 3 different pc's that I have downloaded this camera from before...
  • 462 Answers
Dear daj43
I think u have not installed the software for it on ur pc, incase u have installed the software and still it persists, try to notice if the software is loaded and running when connecting the camera. I would always suggest u to remove the memory card and use it in a memory card reader/writer to transfer the images to pc.
Posted on Feb 07, 2008
I am trying to transfer pics from my camera to my pc ??? i plugged it in and card is in camera but nothing?? help?
Here are some steps to run through to make sure the camera works as you'd expect it:
  1. Ensure that all cables are properly secured from the computer to the camera.
  2. Ensure that the memory card has not been dislodged from the camera.
  3. Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
  4. Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
  5. Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
  6. Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
  7. Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
Hope this helps.
May 05, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
I have a canonA590, when i insert my memory card into my pc port, it won't let me download pics, havn't had this problem before, when i click on download pics from memory card to pc, it comes back and says...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 24, 2010 | Canon PowerShot S2 IS Digital Camera
Sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
May 08, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Connection error
Try to use another USB cord. You can also use a memory card reader to download pics.
Apr 24, 2010 | Jazz JDC25 Digital Camera
Card setup
Then, go into the camera menu and find "reset"...follow the on-screen instructions. Then, insert the card, go into the menu and find "format"...follow the on-screen instructions. Use the card reader to download from now on.
Feb 09, 2010 | Olympus FE-170 Digital Camera
I'm trying to use the usb port to show pics from a digital camera. i don't have a manual
if you connect a camera on a usb your computer will show, a removable device in your computer. under E or F double click, and your computer will show all pictures in your camera
Apr 14, 2009 | Proscan PS36810 TV
How do i download pics to the computer
You should have a patch wire cord that connects your camera to to a usb port on you PC. plug it in turn on the camera to view your pics and your PC should have a box pop up asking you how you want to deal with this connection, transfer- pics to PC pics or something like download pic to a folder to use is My Pictures folder on your PC. when you get them they will be big so you will have to compress them from Mbs to Kbs. if you want to send them in an E-mail. and conserve space on your hard drive.
need more help let me know.
Feb 24, 2009 | Polaroid i733LP Digital Camera
The USB connection is not initiating
there is 2 ways to transfer/download pics from cam to pc (i) the USB connection and (ii) by memory card all you ned is to get the memory stick of your cam and attach it to a card reader and your card reader to a USB port of your PC that way you can download pics from your cam to PC. if still cant understand check this video...
i hope i was able to help you with your problem. gud luk!
Oct 15, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Canon power shot a75
Try a different USB port, it's better to use a USB port at the back of your PC. Try to use another PC as well. You will be able to pinpoint if it's a problem with your PC or your camera... have a nice day!
Sep 30, 2008 | Canon PowerShot A75 Digital Camera
Cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
Feb 05, 2008 | Fuji FinePix S700 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
