Question about Jenn-Air JGS8850ADS Gas Kitchen Range
F1-8 I have been without my oven for 2 months now while waiting for Jenn-Air to send the parts. The oven flashed F1-8, beeped continuously, and now does not heat up at all. Frustration!!!
Problem fixed!!! Lowes is giving us a new stove!!!
Posted on Oct 10, 2009
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Sep 17, 2008 | Jenn-Air Electric Double Oven
I have a Jenn Air Oven that quit working. It
HI - The code described, F3 then F2 both correspond with indicated failure of the temperature sensor. This is a fairly inexpensive part and is easy to replace. The normal resistance of the sensor is 1000-1100ohms. Worth fixing for sure. Complete model number from tag on unit will be needed to get correct part. Let me know if this info helps- have more if needed- Thanks-  Ed
Mar 16, 2010 | Jenn-Air Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Beeping noise - letters appear fc
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JGS8850ADS Gas Kitchen Range Logo
321 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
