Question about Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs
Scotsman CME250 ice machine, compressor will only turn on if you press and hold the button on the contactor. Everything else checks out ok. I dont see anything broke on contactor, so what is supposed to keep the button in for the contacts to touch?
  • Shane Moore
    Shane Moore Jan 17, 2010
    Thanks for your reply. It turned out to be the timer on the board was bad. So the thermostat wasn't receiving its power either. Your solution was correct, the problem was just further back. Thanks again
  • 1,420 Answers
The thermostat energizes the contactor. If it is bad, thus you problem.
Posted on Jan 17, 2010
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How to unlock a Scotsman ice machine code L board lock?
Push and hold in the on button for 3 seconds keep holding then press and release the off twice. it will unlock the controller
Aug 26, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Cleaned ice machine because desale light was on , unit is cleaned and run through clean cycle buy desale light still on
make sure you press the clean button let run 10 min or so then press it again.if you dont press it the second time descale will not reset.
Aug 06, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Can`t get scotsman cme250 to work properly. either doesn`t make ice or won`t harvest ice. when cube size thermostat is turned up so it makes ice it takes long time to start forming cubes. electrical...
The problem could be a series of things beginning with ambient temperatures too high, fan not working properly, if water cooled there could be a problem with that also. As a technician I would first look over the condenser and make sure air flow is proper and then attach my gauges to see the suction and discharge pressures. I have found many restaurants that keep their ice machines in the hot kitchen where it creates high ambient temperatures and allows grease from the grill to collect on the condenser blocking air flow. Yes under charged is possible or over charged but the best and most effective route is to call a Scotsman Certified Technician. I have worked on Scotsman's and they are very tricky to fix unless you know the process of event. If water is not pre-filtered there is a chance that the water control valve may be stuck open allowing warm water to continue flowing causing these symptoms. Here Is a=> Scotsman CME250 Ice Machine User Manual If unable to find these simple checks above or from the manual and still having problems it will need to be time to call a Technician. If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) Tell me what you find and please don't rate me if I was unable to solve this from here. I am here to help you up and to the point of calling Scotsman for addition help. Thanks, Sea Breeze
Jul 15, 2011 | Scotsman Ice Machine, Cuber, 1825 lb....
Scotsman Ice machine cme250 pillow ice maker. 500lb bin. Machine is making ice but sheets of it and not the pillows. Is this due to the harvest cycle is to long so the water is running over the ice and...
If it is going into harvest but the ice is to thick causing it to stick and not letting it drop then you need to adjust the ice thickness sensor it dose not need to be no more distance than 1/8 of an inch between face of sensor and evaporator plate you can use a 1/8 drill bit flat between sensor face and ice plate use a 1/4 nut driver to adjust the sensor.
Jun 21, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I am an hvac student one of my labs is to trouble shoot an scotsman ice machine it will not turn on on with switch i have proper voltage to the contactor but nothing out i didnt know if another process...
The contactor is opeated by the 24 volt controller / transformer. The contactor is CLOSED by the controller to allow current to flow to the fan & compressor.
Charlie
Feb 12, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice machine(sce 275g)
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Dec 22, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs Logo
473 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
