MSI K8MM-V Motherboard
Problem for MSI K8MM-V Motherboard
I've ms-7142 v:1 model mother board in this bios
By prashi4frndz on Oct 08, 2009
i've ms-7142 v:1 model mother board in this bios this not showing the sata option will u plz help me out of this...
Clarification Request
Posted by bertus_kriel on Oct 08, 2009
explain does the board have sata ports, Make does it say anything bout raid in the bois?
Best Solution
posted on Oct 08, 2009
Helpful)
bertus_kriel
Rank: Guru  Computer Components  Expert
Rating: 86%, 21 votes
go into the bois and make sure the sata raid or raid option is enabled, that should fix it
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 24, 2009
Not Rated)
pluerick
Rank: Apprentice  Computer Components  Expert
Rating: 0%, 0 votes
I feel your pain, I just went through this.
Even MSIs SATA drivers didn't help becasue their so-called SATA/RAID driver floppy doesn't include SATA drivers. X(
Here's how I got around the problem. Ridiculous solution but it worked.
You'll need:
1) an IDE drive
2) a copy of Norton Ghost or other drive ghosting utility.
3) another computer that's working.
Here goes.
1) Take out the SATA drive.
2) Install the IDE drive
3) Install windows as if you were using the IDE drive.
4) after the installation can boot or after all the updating is done ( up to you) take out the IDE drive
5) Ghost the IDE drive
6) Install the ghosted image to the SATA drive.
7) Install the SATA drive
The motherboard has no problem BOOTING from a SATA drive with the firmware that came to it, but it wont recognize until after POST, so you can't install windows on it >=(
Anyway those steps will work, assuming you have a computer and an IDE drive laying around.
Huge pain in the arse, right?
Was this helpful?
Yes
No
Popular Solutions for MSI K8MM-V Motherboard
Questions and Unsolved Problems for MSI K8MM-V Motherboard
Do you recommend MSI K8MM-V Motherboard?
Answer
Answer
Sir, I have a Intel 945GCM-S+ICH7 Chipsets Motherboard. I am facing a problem since from last 4... (More)
Answer
I don't know which poles to put the wires on from the power switch to my ices 003 b motherboard
Answer
5.1 out put problem in MSI k8mmv motherboard
Answer
Early Chipset initialization comes on on the D-link. I replaced the the Pwr supply as it was bad but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
