Unplug it, and wait 15 minutes. Then plug it back in. It should come on L. Let it sit another 15-20 minutes. You should be able to turn it up after that.
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
