Question about Nintendo Wii Console
Changed resolution and Wii will not stop rolling on screen. I have a lcd tv 101cm, will work okay on old 68cm tv.
    President:
  • 787 Answers
For best results use the component cable for LCD TV.Make sure the screen is 16:9.Go on Wii menu and check the vertical frequency.If it 50Hz make it 60Hz or back.
Posted on Oct 08, 2009
Testimonial: "The expert was spot on and the problem is fixed thanks Megicate"
I have a Bauhn 40" 101cm LCD TV, went to turn it on and i am hearing a clicking noise through the TV. The screen is fine, but don't know how to stop the clicking noise. So as a result of the the above i...
Short circuited component/s at its audio output stage circuit board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 13, 2015 | Televison & Video
Where to start.....alright. I currently have a softmodded Wii console, and I recently bought third party component cables for it. The cables work fine under Standard TV resolution (480i), but when I change...
From the Wii Channels menu, click the "Wii" button on the lower left of the screen. From there choose: Wii Settings > Screen > TV Resolution. In this menu, click on the "EDTV or HDTV (480p)" option and then click "confirm".
Aug 07, 2013 | Nintendo Wii Console
Wii turns on but nothing comes on screen
Check your video inputs on your TV to make sure they are working then try a known working Wii audio/video cable. If still no video try changing your TV resolution if possible to match the Wii video input resolution. If still no video then you may have a dead Wii motherboard.
Jan 15, 2013 | Nintendo Wii Console
I previously had my wii on an older tv and it worked fine. I recently purchased a new tv (Sharp Quatron Aquos) and when I hooked up my wii and same cables to the tv, my screen is now a hazy black and white...
You are using composite cables(red,white,yellow) mine did the same thing. The aquos is all digital, wont read analog, which is what composite cables are.
They now make a component cable for the wii. I paid $28 at b.b.
Mar 12, 2011 | Nintendo Wii Console
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Big screen for laptop
you did not mention the model of your tv. usually lcd tv's only support some resolutions.
right click on your desktop choose properties then settings you can change you screen resolution there windows will change back in 15 seconds to the old resolution. try the different resolutions availbe to you.
Apr 24, 2009 | HP Pavilion dv1000 Notebook
Gateway 400vtx replaced its broken screen
The resolution on the new lcd is probably different than you're previous model.
Right-click any free space on the deskptop and choose Properties.
Then just choose a resolution that works for you.
Let me know if you run into any problems.
Best of luck!
Mar 07, 2009 | Gateway M305CRV Notebook
COMPUTER WON'T WORK WITH NEW HD LCD TV
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Dec 19, 2008 | Computers & Internet
Samsung 101cm lcd Mounting??
Yes they are the mounting holes but I would not trust a universal mount to hold an expensive TV set on a wall.
Nov 26, 2007 | Televison & Video
Nintendo Wii Console Logo
656 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
