I have a Simpson Eziset 750 washing machine.
The water does want to stop coming into the machine even when you lift the lid up. (This generally stops all machine function). We now have a flooded laundry floor!!
  • 4 Answers
Most washing machines have a length of clear tubing external of the drum assembly (inside the housing). One end connects to the lower section of the drum, allowing water to enter the tubing. The other end of tube connects right up to the top, and usually inside the back panel (where all electrical wiring is) This end is connected to a pressure switch..As the water begins to fill the machine, it also rises the same height in the tubing.The tube is now sealed at both ends. The rising water creates air pressure inside the tube, activates the pressure switch and via electrical contacts closes the water inlet valve(s).
Posted on Nov 17, 2009
    President:
  • 1,304 Answers
You have a bad water mixing valve
it is stuck open
your best bet is to turn the water off and disconnect till it gets fixed
without the model i cant gert you a part number
Posted on Oct 10, 2009
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
My simpson eziset 750 is leaving grease marks on clothes after wash. Whats wrong?
Do you use fabric softener? Too much softener & too many cold water washes results in a build up of black soap residue on the outside of the inner bowl. You could try a hot wash with some white vinegar in the water (No clothes just the water) If that doesn;t work then you will need a service person to come & take the bowl out for cleaning.
Jan 02, 2016 | Simpson Washing Machines
Simpson EziSet 750 washing machine won't drain the water. please help me.
Lid switch faulty, pump blocked, outlet filter blocked (If fitted), pump needs replacing.
Dec 19, 2013 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Simpson eziset 750 t/l stops at first rinse with lid lock led flashing and alarming!
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Oct 25, 2009 | Washing Machines
Annoying beep
Open the control panel and locate the beeper. Pull off one wire and tape over it with electrical tape. Voila! Hope this helps!
Dec 31, 2008 | Washing Machines
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Simpson EziSet 750 washing machine won't spin - what am I looking for to fix it? Appears to be working in all other respects.
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
Sep 20, 2008 | Washing Machines
Washing Machines Logo
374 people viewed this question
Top Washing Machines Experts
