Question about OKI C3100 Led Printer
Toner sensor problems
I keep getting a "cyan toner empty" and "cyan toner sensor error". I just replaced both the toner & drum and I still get the error.
Oki C3200 Drum reset fuse . . . what value should I use?
  • richardsoff Dec 24, 2007
    Sorry I'm a newbie, I did not intend to post the as is but can’t find how to remove the posting?
  • andmicmic Feb 18, 2008
    I have an oki c3200 and i get this error
    Toner sensor error(Black)
    Any help would be greatly appreciated
    Thank you
Hi i have the solucion a error of sensor black oki c3100. For two times i have the problem and a long time study the problem. it´s the solucion. Because i spanish the solution is in spanish languaje.
Desmontar la tapa semitransparente redonda del lateral.
El sensor lleva un iman incorporado que dice a la impresora cuando el toner se a agotado. El polvo de impresion lleva impurezas o las ponen a proposito y hacen que el iman no pueda levantar la leva que hace contanto con el sensor. Con un destornillador limpiar las impurezas que estan pegadas al iman por dentro del toner. Cerrar y listo. YA FUNCIONA JAJAJAJAJAJAJAJA.
Posted on Apr 25, 2008
Sensor window on the drum is closed - or the r/h side of the printer has a sensor that needs cleaning.
Posted on Feb 29, 2008
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
Jul 30, 2014 | OKI C Office Equipment & Supplies
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
Toner Sensor Error for Cyan and Toner Out for Black
First, I wouldn't worry about the "K toner out", it might finally disappear once you get rid of the Cyan problem, if indeed you replaced the black toner for a new and healthy one.
Make sure that the cyan toner cartridge is securely fitted in it's drum unit, and the "knob" that opens the toner cartridge is in fully open position. Sometimes when manipulating inside the printer the "knob" might get moved a bit.
Generally, the toner cartridge sensor is connected via the drum unit, so usually the problem is with proper seating of the drum unit and good electrical contact between the metal fields on the sides of the drum unit and contacts protruding inside the printer. Cleaning both of any residue might help.
Once I had a defective toner cartridge, that caused such problem, but it was the contact between the toner cartridge and the drum that was broken. You have to experiment a bit.
I'm pretty sure in this model it is possible to swap two units - if you swap for example cyan with magenta, and observe if the error moves from cyan to magenta or not, you can draw conclusions if the problem is with the toner/drum, or with the printer not seeing the cartridge for some reason (sensor inputs killed by static electricity for example).
Oct 26, 2009 | Office Equipment & Supplies
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
004-354 cyan atc sensor failure
Hi mgordonO:
The problem is with the toner cartridge or the developer. One or both may be empty.
Apr 08, 2009 | Xerox Phaser™ 7760/DX Laser Printer
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Oki c3400, Have replaced cyan toner 3 times now but still saying toner empty cyan
Check the window on the side of the drum where the sensor sits. It is on the right side of the drum and can be pushed open with a Q tip it is a small black window.
Nov 20, 2008 | OKI Office Equipment & Supplies
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Nov 13, 2007 | OKI C9300 Led Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
OKI C3100 Led Printer Logo
2,007 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
