Question about Fujitsu LIFEBOOK S7110 ,INTEL CORE2 DUO T5500,VISTA BUSINESS,1 YEAR,DL DVD WRITER,1GB (512MBX2),80GB (5400 R... (FPCM42927) PC Notebook
NEC DVD RW ND 6750a CANNOT WRITE DVD-R - Fujitsu LIFEBOOK S7110 ,INTEL CORE2 DUO T5500,VISTA BUSINESS,1 YEAR,DL DVD WRITER,1GB (512MBX2),80GB (5400 R... (FPCM42927) PC Notebook
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: NEC DVD +-RW ND-6650A not responding
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
hope this helps
Posted on Aug 27, 2012
I have an NEC ND-6750A installed in an HP Pavilion ze5570us laptop. I installed it after the original cd drive failed. Windows recognizes the drive but considers it a CD-ROM drive with no DVD...
did you buy this off of eBay? this unit may need to be "flashed" so to speak. the term is firmware upgrade. the HP website has this and i have supplied the link for you. here is thre link for the firmware update:
http://liggydee.cdfreaks.com/disclaimer/en/6750a/261_orig.zip.html
windows should not only recognize it but should reload the drive with the correct parameters.
Feb 21, 2011 | NEC ND-6750A DVD RW Dual Layer Burner
My 6750a won't read disks. I can hear the drive starting to spin, then it gives out after ~.5 sec. it tries to spin again, but the same thing happens. after about 6 tries, it gives up and wont run...
You can here it spinning because it is still working however the lense of your DVD burner might be faulty at this point. Try to use a different CD or DVD for you to see it it will be read by your Burner if not the problem is the lense.
Thanks for using Fixya
Jan 24, 2011 | NEC ND-6750A DVD RW Dual Layer Burner
My dvd drive will not play original dvds or + dvds but will play dvds and cds burn on - dvds and cds
Hello there:
you might need to check to see the format of the dvd that you are trying to play ie dvdr vice dvd some devices will not play them if the format of the cd is wrong
Aug 06, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
ND-6750a not recognized by WinXP SP3
Try the firmware fix and driver installation on this page: http://www.techspot.com/drivers/driver/file/information/9706/
It looks like the "windows updates" outdated your original driver.
Jul 03, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Not displayed in my computer, but displayed in device manager with yellow exclamtion mark code39 driver error
Install its driver I think. If this device is in the yellow mark in device manager. Have it go to update driver or install driver. The exclamation mark should be gone. Or better install its bundled software application
HOPe this one helps
Apr 25, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Dual layer?
captmodley
NEC DVD + - RW ND-6650A is supprot dual layer dvd. for more information u can use this link: NEC DVD + - RW ND-6650A
Thank for asking
Jul 09, 2008 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-3540A DVD RW - problem with erasing RW DVD
try downloading this cdrw soft ware it works graet you can write rewrite and play software dvd 's evrything www.slysoft.com lala linda
Mar 17, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Rewrittable drive reads diks as wrong types
yep Drive is shot
I'd recommended you try upgrading the firmware or using a different media before buying a new one
Dec 24, 2007 | NEC ND-6750A DVD RW Dual Layer Burner
NEC DVD+RW ND-1100A
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Oct 24, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Can't read CD's
CD laser has blown- Replace the drive
May 18, 2007 | NEC ND-6750A DVD RW Dual Layer Burner
Fujitsu LIFEBOOK S7110 ,INTEL CORE2 DUO T5500,VISTA BUSINESS,1 YEAR,DL DVD WRITER,1GB (512MBX2),80GB (5400 R... (FPCM42927) PC Notebook Logo
79 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
