Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Fridge makes loud noise every ~10 minutesq
The Jenn Air refrigerator (bottom freezer) makes a loud(er) noise every ~10 minutes. I thought it was the water pump, but am not sure. The sound lasts for 3-4 seconds and then clicks off.
    Problem Solver:
  • 5 Answers
Does it have a ice machine it it? If yes, that means it is very normal mine does it thats what happens, if no... Then go get a new one, and bring it back. You may have a loose screw
Posted on Oct 19, 2009
What are the typical reasons for excessive ice build up in the freezer of Jenn-Air model JS48SEDBDA? The fan is touching the chunk of ice and making a loud noise.
I have this problem with my fridge if I load the freezer up, and I am talking there is no room for anything else in the freezer. ( bottom freezer) I have to get my heat gun or use a blow dryer and go over the vents in the freezer and thaw them out ( if they look frosty ) this has solved my refrigerator problems.
Mar 07, 2015 | Jenn-Air Refrigerators
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Replaced water filter when trying to get water it HONKS loudly and no water comes out
You might have air in your system. Hold the dispense lever down for several second about every 10 minutes until you have the air purged.
Jan 15, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
The refridgerator is making a loud buzzing noise every minute or so. The fridge and freezer temp is rising. Tried to restart the power and that did not work
The compressor is trying to start but it is not starting....
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 28, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
JFC2087HRP Jenn-Air freezer creaking noise.
Most of the time this happen when the refrigerator has been hooked up to the water, and than you unhooked it!!, the water that is in the hose makes that sound when it's pushed by the air in the hose. that's a typical problem when you unhooked the water.
May 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
374 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
