I have a ten year old bose av3-2-1 and the fuse burnt out. is the thing marked u25 the fuse i need to change
  • walsher Oct 08, 2009
    yes, i at least i know what the fuses look like and are numbered. What happened was i was re-wiring my house and crossed a wire. When i turned power back on, i had to much electricity flowing through the wire, and it fried the system. Do you know what fuse that might be?
    thanks
    thanks, hope for more info
    Brigadier General:
  • 3,614 Answers
you also have to identify what ampere does the fuse have.
Fuse F4 is required at any time to provide a +5V power from the VME backplane any type) for three on-board voltage regulators U23, U24 and U25. Fuse F1 is needed at any time to provide a +1.5V for the FPGA core from the on-board voltage regulator U23. Fuse F3 is also required at any time to provide a +2.5V power for the TLK3101 transceivers from on-board voltage regulator U24. Output value of the U24 can be adjusted with the potentiometer R52. Fuse F2 is needed to provide +3.3V power for onboard devices if VME64x backplane is used. Fuse F5 is needed to provide a +3.3V power from on-board voltage regulator U25 when a conventional VME backplane is used. Only one (either F2 or F5) should be installed at a time.
Hope this info help you.
Let me know for any clarification
Posted on Oct 08, 2009
If i change the transformer of bose wave from 110 volts to 240 volts would i change the fuse
No, because the internal fuse protects the circuit after the transformer. The fuse should be marked anyway. If it says 110 volts, 5 watts, then you would need to swap it for 220 volts 5 watts.
You can of course ask Bose direct.
Better Sound Through Research Bose Worldwide
Aug 16, 2017 | Bose Audio Players & Recorders
No sound Bose wave
I took mine back to the Bose store and they gave me credit on my Wave that was about ten years old toward a new CD wave radio. I would recommend taking it to the Bose store and see what they can do for you.
Sep 11, 2014 | Bose Wave Radio
Why does My Bose Wave AWR1C2 radio only works on the alarm. Radio has no sound
My radio stopped working. I was able to take it into a Bose store and trade it in on a new radio. My old one was about ten years old and it did not have a CD player. I was able to trade it in on a new one with a CD player.
Jun 28, 2014 | Bose Wave Radio
Remote stopped
hey Mark sounds like the antenna poped loose ..its a solder thing..[1]bose might fix it $45.[2]ebay replace $100 & up [3]i will list one tomorrow on amazon $105. total factory refurbished [4] return your old one for a$25 recycle + i pay the shipping........amazon bose remote RC28T1-28........bookbundler@gmail.com
Feb 15, 2014 | Bose RC28T1-27 Remote Control
Cigaret lighter
cigarette lights draw considerable current flow so look in the engine compartment for a fuse of at least 25 amps.. It will probably under a plastic cover and marked cig
Dec 23, 2013 | Cars & Trucks
I have a ten year old bose wave/radio/cd player. Sound is great but want to play music from my ipod through the bose. my ipod plays in car using aux cable but this does not have same result when...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jun 17, 2011 | Bose Wave Radio
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Oct 20, 2009 | Amana PTH153B50AE Air Conditioner
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Apr 09, 2008 | Bose Wave Radio
70 people viewed this question
 Grubhead
Grubhead
