Question about HP OfficeJet 6110 All-In-One InkJet Printer
My Hp Deskjet F4200 series printer will not scan anything to my computer, but it will copy just fine. How can I get it to scan? I have already uninstalled the printer driver & reinstalled it. It says everything is working just fine. I can't get the alignment page to reprint. I had to send my computer to HP awhile back for a keyboard issue & when I got it back I had to reinstall everything. Well I got the test alignment page & didn't think anything of it & threw it away. I didn't know I had to redo the whole scan alignment page thing. Am I doing something wrong??? Do I need to call HP???
    Scholar:
  • 121 Answers
Check to see that your Scanner drivers have been installed. Click on Start, then Printers and Faxes and see if a Scanner is listed. If not, you need to install the drivers.
Also, when you uninstall the printer drivers, you first need to disconnect the printer from the computer, and unplug the printer from the power source. Leave the printer unplugged for at least 15 minutes to clear the printer's cache memory.
Next, go to Add/Remove Programs in your Control Panel and uninstall the printer software. Then, turn off your computer.
Next, reboot your computer. Place the Deskjet cd in the drive and follow instructions for reinstalling the printer software and drivers.
CAUTION: DO NOT PLUG IN YOUR PRINTER CABLE TO YOUR COMPUTER UNTIL PROMPTED BY THE INSTALL DISK!!
Posted on Oct 08, 2009
Tip
HP Deskjet F4200 Series All-in-One Printers Protection Fault Problem
A lot of HP Deskjet F4200 Series All-in-One printer users complain about the installation problem experienced with this product, especially those using the Windows XP operating system. The driver installs perfectly; it performs the alignment and prints the test page. But as soon as you print a document, photo, or anything from the computer, the printer fails and says "The program has encountered a problem and needs to close". When you go to the printer properties, you'll get a message: Function address 0x500a0490 caused a protection fault. (Exception code 0xc0000005) Some or all property page(s) may not be displayed.
The problem can be resolved by completely uninstalling the driver and installing it again. When the installation is complete, click the START button on the lower left corner of your screen then on the right pane, click 'Printers and Faxes'.
Under the printer tasks, click 'Add a printer' then click Next on the Add Printer Wizard dialog box. Select 'Local printer attached to this computer' and uncheck 'Automatically detect and install my Plug and Play printer' then click Next. Click 'Use the following port' and select LPT1: (Recommended printer port) then click Next.
Select HP under the Manufacturer list and under the Printer list, select hp deskjet 990c then click Next. Select 'Keep existing driver (recommended)'; click Next, name your printer, select Yes to set your printer as the default printer then click Next. Select Yes to print a test page, click Next then Finish to complete the setup. Click OK when a dialog box appears.
Go back to the 'Printer and Faxes' folder and right-click on the name of your printer. Select Properties and click Ports/Connections then check 'USB...Virtual printer for.....hp deskjet 990c'. Click Apply then OK and you should now be able to use your HP Deskjet F4200 Series All-in-One printer.
on Apr 11, 2010 | HP DeskJet F4280 All In One Printer InkJet
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
How do I load the ink cartidges to a F4200 H P printer
This tutorial from HP support shows DeskJet F4210 which should have the same procedure:
HP F4200 Series Replace Ink Cartridges
Jan 16, 2010 | Office Equipment & Supplies
I have a HP Deskjet f4200 All-in-ONE Series but I don't know how to scan from it to my computer.
The operators' manual will explain this procedure.If you don't have one HP's webite will have it
Sep 28, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp f4200 printer how to install have lost instructions
www.hp.com/hpinfo/newsroom/press_kits/2008/.../fs_f4200.pdf
www.user-guides.co.uk/.../hp/.../hp-deskjet-f4200-free-software.html
here is two different links you can copy and paste in your internet address bar. One is for instruction manual, the other is to download the software if you don't have it already.
Sep 09, 2009 | Office Equipment & Supplies
Hp F4200 deskjet problem
Please follow the best option that are given :
1) Check all the cable.
2) Check you cartridge position and install it correctly.
3) Remove the old copy of your driver and try to download latest driver from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=14438&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us and install it.
4) If cartridge condition or its refill time is over then try to use new cartridge.
Feb 22, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP OfficeJet 6110 All-In-One InkJet Printer Logo
3,656 people viewed this question
Seeker5211
Seeker5211
