Question about Toshiba Computers & Internet
Can u overclock the cpu in a toshiba p505ds8935
  • neolazurus Oct 08, 2009
    ok can you allow more ram to vedio there hase to be a way
  • 4,281 Answers
Yes for that when you power up the computer press F1 or F2 or "del" key then you can see bios setup screen.
Then go to advanced option then incrase or decrease shared memory with graphic.
Then save settings and exit.
Let me know if you need more assistance.Thanks.
Posted on Oct 08, 2009
    Brigadier General:
  • 3,614 Answers
Hi, No, the unit cannot overclock, this is a mid-range product it contains certain features are typically found on higher end products. Hope this helps
M115 s1061 overclock
Overclock can be done by setting fsb higher by percentage to speed up cpu frequency by percentage. But some cpu can not be overclocked and may overheat and shut down. And some drams can not be changed to higher fsb.
Apr 03, 2012 | Toshiba Satellite M115-S1061 Notebook
How can I safely overclock my Toshiba Satellite L675D-S7106
Without changing the CPU and updating the motherboard firmware I don't even know if you can do that as it depends which chip is fitted and how old the firmware is.
Feb 25, 2012 | Toshiba Satellite L675D-S7050 Notebook PC
Overclocking
There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one.
http://www.asus.com/Motherboards/AMD_Socket_A/A7V880/#download . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
Nov 27, 2011 | ASUS A7V880 Motherboard
How to overlock my e5500 2.80ghz to 4.5ghz???? or the highest overlock that can e5500 dual core
Hi there, your first going to need better cooling for your cpu like a aftermarket cooler and then go into the bios and raise the cpu multiplier and cpu voltage bit by bit
Mar 03, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
How do I overclock my cpu
Hello
Some CPU's overclock with diffirent methods, so, you do not specify which you are using, so, i googled step by step guide to overclock CPU. I found detailed instructions on how to overclock different systems. Hope this can help you.
Best regards.
Sep 30, 2009 | Dell Computers & Internet
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Overclocking t-mobile wing
[WARNING - Overclocking your CPU will at least reduce the life of your processor but may fry it at worst - USE CAUTION]
There are a couple of apps you can use to do this:
OmapClock
BatteryStatus
I prefer Battery Status because it remembers your CPU overclock whereas OmapClock requires you to reset your CPU on wakeup. Also, BS has a "CPU Scaler" function (UNDERclocks your phone when it is not in use, then OVERclocks it when you wake it up...Pretty cool)
Anyway you will get instructions on the site on how to use each one specifically. They are really easy to use.
Jun 23, 2009 | T-Mobile Wing™ Smartphone
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
Overclocking!!
If this a Notebook/laptop, please do not try overclocking, it may damage CPU/other components..
Jun 25, 2008 | Toshiba Satellite A45-S250 Notebook
Computers & Internet Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
