Question about Kitchen Ranges
Oven does not heat but broiler does.
The oven was working, it beeped when it reached the temperature I had selected. Then a couple of hours later I was going to throw some ribs in and found the oven cold as ice, even though the panel indicated that the oven was preheated and ready to use. Now beginning about six months prior to this I thought the oven was taking longer and longer to reach it's preheated stage. But I thought I was just imaging it-until it started taking almost a full hour to preheat that is. This is a free-standing GE range XL-44 gas with self cleaning feature. Where would I find the model #? The owner's manual is generic for twelve different models. The models it lists are EGR2000, JGBP24 thru JGBP28, JGBP30 and 40, LGB356, RGB744 and 745 and 845.
    Sergeant:
    Champion:
  • 205 Answers
Hello mam please visit the manufacturers website there you can find it.
Posted on Oct 08, 2009
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
My oven has increased only 65 degrees in almost an hour....what does it mean when it heats up, but SLOWLEY??
The broiler element on the top of the oven comes on during the preheat cycle to speed things up and then only the lower element keeps the temperature steady. One of those elements is bad, probably the broiler. Try using the broiler and see if it works. If not, you need to disconnect the elements from the oven and check them with an ohm meter. If gthe elements check out ok, then it must be the temperature sensor/thermostat.
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Electric stove oven does not obtain proper temperature and does not cycle
This is a very generic question. If it is an old electric range with mechanical controls, the thermostat may not be cycling properly. Most new electric ranges use electronic sensors which send a signal to a board. This signal changes as the temperature changes. Technically, the resistance of the sensor changes with the temperature and that resistance is the input for the circuit board. The circuit board then adjusts the temperature according to the signal it is receiving from the sensor. A good technician should be able to check the resistance in the sensor to see if it is within acceptable range. If the sensor is good, they would be able to troubleshoot the board or other controls.
Nov 01, 2007 | Stoves 1100DFSID Kitchen Range
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
296 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
