Question about Electrical Supplies
NO AC OUT
Buffalo generator 6000 13 hp runs good, no AC out put need wiring diagram to receipts.
  • 98 Answers
Please send me a pic of you generator wire outputs:coil, brushes...)
and i'll be glad to help...
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Mar 31, 2014 | Buffalo Tools Sportsman Series 4000 Watt...
On/off switch buffalo bench grinder
The switch is probably generic.. go to a Lighting store and see if they have equivalent
Nov 20, 2013 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I need a gas tank for a 4000 watt Buffalo generator.
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
Feb 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
WHO MANUFACTURES THE ENGINE FOR THE BUFFALO TOOLS GENERATOR EX: 4000 W OR 10000 W SIMPLY PUT WHAT KIND OF ENGINE IS ON ANY OF THEM
There have been several factories in china that have made the motors used on buffalo generators, a couple of these are Lifan and J.D. as in Jiangdong.All of these motors are very similar to honda motors.The 6.5,13,and 15 h.p. motors are real brutes and hold up very well.
Jan 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Need to know battery ttype
Some of these are delivered with gel cell type batteries. They are often undersized and have limited starting capability.
Frankly the best way I have found is to MEASURE the maximum size fo the battery and note the terminal type. The go to the NAPA site and check the dimensiona to find the biggest battery you can fit in... usually a motorcycle type. Usually you need one that has lugs with holes to use bolts to attach the wires.
Jul 03, 2010 | Buffalo Tools 5500 Watt 13 Hp Ac Delco Gas...
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
NO AC OUT
hello sir/mam
please visit the manufacturers website there you will get it.
Oct 08, 2009 | Coleman Powermate Powermate 5000W...
hello sir
please visit the manufacturer website it will help you.
Oct 08, 2009 | Plumbing
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Portable Generator doesnt generate any AC Current
is there a manual reset circuit breaker somewhere?
Dec 21, 2008 | Electronics - Others
Electrical Supplies Logo
164 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
