Motorola SURFboard SB4220 Modem
Problem for Motorola SURFboard SB4220 Modem
I'm trying to hook up my modem through my router.
By blitzkraven7 on Oct 08, 2009
I'm trying to hook up my modem through my router. My last router had an ip address of its own which I used to tell it to work through the router. Does the sb4220?
Comments:
Oct 09, 2009
- My modem works (receives and distributes internet appropriately to one device at a time) but it doesn't work through my router. I know the router works fine because I removed it from another computer and had to reset the modem and tell it to run specifically through the computer. So back to my original (and as yet unanswered) question: is there a standard IP address for the sb4220 modem?
Solution #1
posted on Oct 08, 2009
Not Rated)
johnrray7526
Rank: Guru
Rating: 90%, 406 votes
You may want to have the modem working with your system first and hook up your router after wards.
Disconnect your router and modem.
Reboot your system.
Run your hard wire direct to your SB4220 from computer net card.
Allow to load whatever drivers necessary.
On your computer type ipconfig /all This will show you all your information.
Try the internet and see if it works. If you know the ip of your carrier, Type ping ????? ie: Ping comcast.net
If you recv. a timeout you still have problems.
If you succeed, you are their.
If not, type ipconfig /renew This will reset your ip and configurations.
Now, hook up your router and you should be their.
Comments:
Oct 09, 2009
- In answer to your question, yes the modem does have its own IP address. You can not use this IP and it can be found on the bottom of the unit.. Look for Mac IP
Again, the information in which I gave to you prier to this comment, is the best way to obtain your IP configuration.
Was this helpful?
Yes
No
Popular Solutions for Motorola SURFboard SB4220
Questions and Unsolved Problems for Motorola SURFboard SB4220
Do you recommend Motorola SURFboard SB4220 Modem?
Answer
Answer
I need to recover philips sna 6500 pasword to add wireless printer to lan
Answer
I have a Geo-Vision Multi-Cam security system that works fine on my local home network; 3 computers... (More)
Answer
Trying to setup "Yawcam" to allow my webcam to be visible over the Internet. Motorola... (More)
Answer
I have no problem listening to radio on my personal Apple Laptop, using email or the internet. But... (More)
Answer
Got a SB4000 given my cable company, got a SB4220 which is mine, tried connecting it but does not... (More)
Describe your Modems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Modem Experts
Top Computer & Laptop Repairmen
in , IL
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
