Jsi pro-24 Plotter for vinly cutting has a code on my software error code 19
  • 10,515 Answers
It seems to be a corrupted file error. Uninstall and reinstall the software and check, if that could fix the issue.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 08, 2009
SYSTEM ERROR 20:10
Error Code 20:10 does not appear to be a valid code. Could you verify that is what is being displayed? What is the plotter doing when the error occurs?
Oct 03, 2013 | HP DesignJet 800ps (24 in.) InkJet Printer
I have a cutting plotter,, its a ShanghaiJintiar JT720.. works with Artcut6, <--this is what came with it. I want to use corelDraw with this plotter.. looking to make lettering with background...
basically you set corel draw to the paper size (vinly) your using.. click outside the page and set it using the selector on the tool bar..
once thats done,, click print,, select your plotter,, set your properties your using if not leave at default,, hit print..
Jul 12, 2010 | Sport & Outdoor - Others
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
I am trying to use my DGI Cutting Plotter and when i try to start up the program Omega Cut Pro it comes up with a message to say 'Protection Failed, Please Check Your Dongle' I am unsure what this means...
Ok this means that to use this software you MUST have a licence and along with this you get a "Dongle" a device that plugs into either the Serial, Parallel or USB port, and has a "Code" in it, that is "Read" by the software. You simply cannot use it without this "Dongle" & Licence.
Feb 10, 2010 | Computers & Internet
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Printer cutting off 5 inches from finished size from InDesign
teresa_marti,
Try to rotate from lanscape to portrait, or if plotting form Acrobat check auto rotate and denter from the properties. Since it pltted before and no resizing was don it has to be the printer preferences.
randy320sgi
Jan 07, 2009 | Adobe InDesign
JSI dvd player, remote code
I have similar problem, solve it with codes from Koss brand.
Jsi and Koss are made by same lab.
Try Koss codes, it work for me.
good luck!!
Dec 29, 2008 | Progressive Computer JSI 6 spkr. Home...
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
108 people viewed this question
jasbo
jasbo
