Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Homelite chainsaw mod 4620c will start and windup and die
    Problem Solver:
  • 14 Answers
Sounds like it is getting lean (running out of fuel) then dies. Clean and inspect carb and fuel lines.
Posted on Oct 08, 2009
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
Homelite chainsaw model 4620c will not idle unless it is in the half choke position
If the jet screws have slot heads, set 'L' CCW about 1/2 turn more or less. If proper, the engine should idle fairly well, yet allow the engine to 'follow the throttle'. If the jet screws have 'D' heads, you will need to either make a 'D' head screwdriver, or take the saw to a service dealer for adjustment. If the chain is trying to turn after the above adjustment, set the idle speed screw CCW until the chain stops trying to turn. Hope this helps!
Oct 18, 2010 | Homelite Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a Homelite Pro 4620c chainsaw. the primer
take nipple assembly apart clean thougholy with engine degreaser or simular product then seal onthe inside with rtc silocone sealer l
May 21, 2010 | Homelite ZR10926 16 Chain Saw
My homelite 16 dies constantly
Does it suddenly stop running? (probably electric) Do this while still hot:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Or sputter and slowly quit (like out of gas).
Try loosening the fuel cap (rotate the saw if necessary). If it smooths out, runs and accelerates correctly you have a plugged fuel vent. HTH
Lou
A local chainsaw seller/mechanic (Stihl best mechanics in my area) can diagnose for about $10. A repair and tuneup usually $40 - 60. Your starter arm will thank you. If tuned ask what fuel mix they used (should be 50:1) and affix a tag or label to your saw.
Nov 09, 2009 | Homelite Garden
Tune up specifications
Engine starts OK but dies when reved up
Aug 09, 2009 | Homelite Garden
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
399 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
