Question about Kenwood Car Audio & Video
Need a diagram of hw to hook 2 subs to 4 channel amp
    Problem Solver:
  • 8 Answers
Posted on Sep 01, 2012
  • 21 Answers
No diagram but you can printthis out. Choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) You need to put the settings to low hertz and no high settings. Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides!). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps
Posted on Oct 08, 2009
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
Looking for info on how to hook up sub to this amp thunder4160
Hi, you have two choices for hooking up a sub to the 4160 amp. You can either connect your sub to one of the two available channels, or if the amp supports it, you can bridge channels 3 and 4 to get increased power to your sub. You have a 4 channel amp - channel 1 and 2 go to your 3-way speakers up front, which leaves channel 3 and 4 available for your sub.
Jul 27, 2013 | Car Audio & Video
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Rockford fostgate p500-2 amp overheating pls help!
Your Amplifier:
125W x 2 @ 4-Ohms RMS
250W x 2 @ 2-Ohms RMS
500W x 1 @ 4-Ohms bridged RMS
Your Subwoofers = Dual 4 ohm
Possible wiring configurations of (2) Dual 4 ohm voicecoil subwoofers are:
2 ohm Stereo
1 ohm mono
4 ohm mono
That amplifier is not 1 ohm mono stable.
You need to put a 4 ohm load on the "bridged" terminals of the amplifier
Your best wiring configuration is going to be Series-parallel.
CLICK HERE to see the pic Larger
4721108.jpg You can also get the same result (power) by having the subs wired in parallel independently. Put both + on one sub to one + on the amplifier and both - on one sub to the - of the same channel of the amplifier.
Repeat for channel 2.
This will be a 2 ohm stereo load.
You should only use this method if the subwoofers are in seperate enclosures... not one big cavity.
Thanks for using FixYa -a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Rockford Fosgate Punch P5002 Car Audio...
How many speakers can I use?
This should work if channel 3 & 4 are bridged at 4 ohm.
channel 1 should be stable at 2ohm
channel 2 should be stable at 2 ohm
You can hook up the right side speakers together ( + with + and - with - ) . same thing with the left side. this will give you 2 ohm each channel. this will cause your amp to run hot (this might be tuff on the amp). It will give you right (2 speakers) and left ( 2 speakers ), no front and rear adjustement if you need to balance your sound. I think you should be better buying another amp for your sub and take your 4 channels for your 4 car speakers. this amp as a rca output that can feed the other amp ( sub amp ). it is possible to do it.
Good luck
Nov 11, 2008 | Alpine MRP-F250 Car Audio Amplifier
Is it a good idea
Based on your description and on the idea of a single amp, then your plan of hooking up both the subwoofers in series (to get 8 ohms) would be the safest as against running the subs in parallel (2 ohms). This way the sub amp would not be overly loaded, you can compensate the slight loss in power by strategically positioning the 2 subs. A friendly reminder, pls observe polarity when hooking the sub speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Car Audio & Video
Hooking up DVC subs
The amp is rated to run a 2 ohm load on each channel. To do this, connect the voice coils of one sub in parallel (tie both "+" on the sub to each other and both "-" on the sub to each other), then connect that sub to one channel of the amp. Repeat this process for the other sub and connect it to the other channel on the amp. The subs will be in stereo and the amp will be outputting it's maximum power.
Mar 09, 2008 | Legacy 2CH 1000W AMP Car Audio Amplifier
Car Audio & Video Logo
122 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
