Question about Sony Playstation 3 (PS3) Console
Game stuck/blinking red light
I was in the middle of a game, game and system shut off. Turn game back on hold the eject button, turns green and then I get the blinking red light and it shuts off again. How do I fix this and get me game back?
I was playing mw2 yesterday and bam (red light of death) ill prob have to send it to sony but i got the game out follow these steps. 1. turn off at the back. 2. hold your finger on the eject button. 3. turn on again at the back while holding the eject button for a few seconds 4.your playstation should start up and your game should be ejected
Posted on Nov 14, 2009
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Went off in the middle of a game and now the system light will turn green and then blink red and the game will not come back on.
Does the lights blink red? If so, you have the infamous YLOD, aka. Yellow Light of
Death. This is the number 1 cause of pS3's dying. It is an overheating issue
linked to your CPU and GPU (the processor chips) You will need to find a local PS3
repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself. You could make things much worse and render the unit totally unresponsive.
The repair process takes about 3 hours.
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you
can retrieve your disc.
and eject your disc. Remember, this will only work on the 20, 40g models. Not the
Jan 17, 2011 | Sony Playstation 3 (PS3) Console
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
I was in the middle of loading my franchise on madden when it turned off, i tried turning off the back switch and to turn it back on. the green light turns on for a second then another color of green light...
Again, people assume because it is blinking red that it is the "YLOD", better known as a hardware failure.
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Take care.
Aug 30, 2010 | Sony Playstation 3 (PS3) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
In the middle of playing it shuts off and a red light starts to beep and flicker on and off
Unfortunately, you are going to need to have your PS3 serviced by Sony. If your disc is stuck inside, if flip the switch button off on the back of the PS3. Then press and hold the eject button and turn the button at the back on again. This should eject the disc.
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
I have playstation 3 model # CECHH01, a game is inside, when i power on the light goes green, then quickly goes blue then yellow and goes back to red and powers off leaving the red light blinking. What do...
well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
My console starts to turn on ,then shuts down!!!
try reseting your video settings by holding the on;off button for about 5 seconds when turning on . if this doesn't work, must be a problem with your hardware. then you should take the system to a support centre.
about the disk, have u tried to turn the system on by pushing directly the eject button ?
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
Disc won't eject
press the disc eject button
Jun 25, 2008 | Sony PlayStation 2 Slimline Console
Sony Playstation 3 (PS3) Console Logo
359 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
