Question about Frigidaire GLER331A Electric Dryer
How can I remove the back panel to my dryer model number FER641FSO Frigidaire
  • Frigidaire Master
  • 8,220 Answers
Actually you werk from the front on that there particular dryer Kimosabe. Take a LOOK HERE
Posted on Oct 08, 2009
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Where is the heating element located on the model #FER641FSO?
the element is located behind the drum itself and the drum must be removed in order for it to be accessed. this requires popping the top of the dryer open as the are metal clips that hold it closed it will take a flat screwdriver to wedge it the crack and give it a good pop so that the handle of your driver moves towards the floor when you pry it open.Be sure to shut off the breaker as well as unplug thew unit before you do anything at all.the drum will slide out relatively easy but you must remove the belt by accessing it usually through the front bottom panel(metal clips) be sure to remember how the belt goes on the pulleys as it can be tricky to put it back the same way it was. this is impotant because there is a swithch under the arm on one of the pulleys that if its not assembled proprly the switch will not be depressed and it will not run.
Oct 07, 2010 | Frigidaire FER641FS Electric Dryer
Our dryer is a model # fer641fso. it is notgetting the clothes dry without running 2 or tree cycles. the dryer is very hot to the touch in the back and very warm on top. the vent is hooked up properly. any...
u have a clogged vent,,, undo vent to dryer run a load if heats faster then replace dryer vent, and clean out ur ducting with a leaf blower blow that ducting lint outside.
Feb 03, 2010 | Frigidaire FER641FS Electric Dryer
Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Aug 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
Valh my dryer model fer641fso wont start when i push the start button it does this low beeping sound bought brand new only owned for 5 months worked fine all day yesterday stopped working last night.
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly. OR The start capacitor may have failed and i would not suggest you deal with that as they give out a nasty electrical charge, also check and clean all filters and check your user manual for further advice as your machine should still be under warranty, call the numbers listed in your manual. good luck
Jul 19, 2009 | Frigidaire Electric Dryer
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
I NEED YOUR HELP
hi tanks for the question you could have a bad motor or something caught in the blower i would check the blower thanks the appliance doc
Sep 26, 2008 | Dryers
Frigidaire GLER331A Electric Dryer Logo
484 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
