Question about Akai LCT2721AD 27 in. LCD Television
When i press power button only red light flashin and i hear
  • 10,515 Answers
This seems to be a duplicate Question. Kindly check the reply from all experts - They mentioned Power Supply.
What's the best i could do, i could provide you with the contact information for Akai. I am sorry, but we cannot change mindset. As you have made sure, you would find a magic button which is not there, the best option would be the company directly. The contact information for Akai :-
323-281-0782.
You can also write an email to :-
techsupport@akaiusa.com
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 08, 2009
  • taran_2005
    taran_2005 Oct 08, 2009
    I have worked on a ton of them and the power supply is a simple
    switch mode supply that uses a few fets to take the Line voltage of 120
    volts @ 60hz AC to a few different DC voltage supplies like 24vdc, 12v,
    5v, 3.3v and 15v all DC which is what most electronics run on...
    This
    set is made by ESI International and the can be fun to get parts from
    so your best bet might be to repair the supply instead of replace.
    First
    remove the back cover, which means laying the set on its face on the
    floor and removing the stand as on this unit the stand block the cover
    from being removed. To lay it safely you will need a large area and
    make sure it is very clean and VERY LEVEL as because this is a LCD even
    the slightest pressure on the screen itself can cause the LCD to crack
    so make sure the pressure is only on the front cover around the LCD
    itself.
    You will see a board that the power plug connects
    to this is called the small power supply. This is your most likely
    failure look at the board and you should see some cylinders with a
    silver top they should all be flat if they some are not the board is
    most likely repairable. The parts will cost you about 20 bucks (when
    you include shipping and the "not a servicecenter" extra fee most
    places rob you with) If you do not see any of these swollen caps (the
    silver tops) then the power supply most be replaced they can be
    expensive ranging between $100-$250 for the part. First i would open
    and see if you can save a buck and repair it by replacing the damaged
    caps. If you dont feel comfortable with replacing the caps this could
    easily be repaired by a local repair shop for under $200.00 (if they
    are reputable).
    If you wish to order the power supply contact vance baldwin electronics (http://www.encompass.com/) or call them at 800 432 8542
    You can also contact http://www.fox-inter.com/ they are the authorized dealer for Akai Parts.
    If you wish to attempt this repair yourself:
    read
    the numbers down the side of the capacitors they should have a white
    stripe (neg side always install them the same direction) and then they
    should be marked like this 1000mfd 50v or the "1000mfd" is the micro
    farad rating this is a contant do not install anything but the same mfd
    rating but the "50v" is the maxium voltage rating and this you can
    increase to anything that will fit 65v 100v 200v or larger but never
    smaller. The bigger the voltage the bigger the size of the cap.
    You can order the parts from http://www.digikey.com/ expect to pay around $20.00 for the parts but you will need a good pencil soldering iron, solder and desoldering braid.
    If
    you dont have the tools and materials the cost of the equipment will be
    more then the cost of having it professionally repaired and when you do
    it if you make a mistake your ordering a $300 power supply, and it
    doesnt carry a warranty.
    If you have the tools it is simple enough if you dont you can order them from www.mcminone.com
    it has to be adjustable and at least 40w
    21-3475 - WLC100 Solder Station is the cheapest one i could find that would suit your needs
    20-2788 - Solder-Wick Rosin - .110'' x 25'
    copper wick, this is the only stuff i use there is some really cheap
    stuff out there and it is horrible to work with in supplies.
    21-1840 - 44 Rosin Core Solder - 60/40 - 1 lb. x .031'' - 21 Gauge this is the solder you will need.
    Hope i helped you.
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tip
How to fix your PS3 when it's frozen at startup
1.The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
2.Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
3.Time to enter Safe Mode.Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
4.Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
5.Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
6.Select option number 3, (Restore File System). Then select yes to perform step.
7.You will then see this screen. "The hard disk's file system is corrupt and will be restored."
8.First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
When I turn on my PS3 will not load the basic applications, neither the games. When I press the PsS button on the cotroller to turn it off I will get the option but it will not tunr off and i will get a...
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button AGAIN, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
*****CHOOSE RESTORE FILE SYSTEM WHICH IS OPTION 3****
and DONE!!
www.1RepairStop.com
Aug 25, 2011 | Sony Playstation 3 (PS3) Console
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
My PS3 has no menu. No sound or video
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My sony erricson won't turn on all i see is a red light
Try this.
  1. remove the battery
  2. press and hold the power-on button for 15 seconds
  3. release the power-on button
  4. connect the power supply
  5. with the battery still out, try turning the phone one
  6. if it works, disconnect the power supply
  7. reinstall the battery
  8. connect the power supply
  9. turn phone on
  10. allow phone to charge battery
If that works, you should be okay from that point on.
Jan 12, 2009 | Sony Ericsson w580i Cellular Phone
Tv wont turn on no more it was fine this morning then is turn off i try turn on and off the power light turns green the click off again and it turns red flashin plus the sleep light red as well flashin plz...
I had a problem with my Sharp LC-15e1u where it will not turn on
by pressing the LARGE RED pb on top. The power button remains red. It also used to be green. Well I tinkered with it and
found by starting with the power OFF,
Press both Menu & TV/Video
Turn on by pressing the Big Red Button
The power lignt is red for one second then turns green.
The TV Then turns on leaving you on channel 58.
The volume control slides from 0-30-60 and back to 0.
Also there is a small "K" in the upper left corner of the screen.
I'm returning the unit for a Factory warrenty. I bought it on
clearance "AS IS".
I hope this helps...
Mar 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Akai LCT2721AD 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
