Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
My pool heater says to check the ignition control, it is a Jandy model LXi
  • 8,220 Answers
Look for a loose wire or corroded ground wire to the igniter. If the brain cannot get a signal of ignition, the flame will prematurely shut down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 08, 2009
Y Jandy LXi pool heater will not start, it keeps reading no flow although all valves are properly set.
check preesure switch to see if voltage both sides if not clean out copper tube probably calcified
Mar 15, 2015 | Jandy Lxi Natural Gas Pool Heaters
"fault check ignition control
turn heater off then turn back on make sure gas is on
Jan 04, 2014 | Jandy LXI 300 PROPANE POOL HEATER -
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
The heater won't light up on my Jandy LXi400n Lxi heater
make sure red light is on for calling for heat if so make sure 24 volts ac on both sides of pressure switch if ok make sure gas is on
Jul 13, 2012 | Jandy LXI400N Lxi Pool & Spa Heater -...
Jandy lxi heater low pressure warning
check filters if ok check pressure switch and tube going to it
May 17, 2012 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Ignition fault LXI pool heater 400k
if ignitor is working try to adjust air damper make sure gas pressure is ok
Apr 12, 2012 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Won't ignite
make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Jun 02, 2009 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
116 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
