Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I just replaced my bulb and not the red status light stays on what do i do? there used to be sounds when the bulb originally went out but now there is nothin
  • 10,515 Answers
Make sure to check or defeat the micro-switch for the filter cover, and for the lamp, these can also cause red lights..
Here is the Honest truth...
From what you are describing, I would say that you are encountering the "famous" problems of the mitsubishi v26 chassis based tv's - Mitsubishi has used this chassis in almost ALL of the DLP tv's they made, and they are loaded with problems..In my opinion they are complete lemons.
There are almost 50 capacitors in this set on the DM board, Format board, power supply and the terminal boards that were cheaply made, and go out of specs making this tv do many different "strange" things until the capacitors on the DM board go bad, and the tv will simply sit flashing the green timer led and do nothing. This is known as the "flashing green light of death" -- The red indicator with a good lamp is an indication that yours may be on its way as well.
You may want to google "mitsubishi dlp lawsuit" I have heard of several class-action suits against mitsu for these sets.
Mitsubishi is supposedly offering a refurbishment service on these chassis' and I have heard several different prices - from $250 to $850... you may want to give mitsubishi a call and see what they say, but honestly for that kind of money, I would recommend investing it in a new set..
I have worked on several of these sets, and i now wont touch them due to the fact that they are so problem riddled--between the bad capacitors in the chassis, the light engine problems and the bad thermistors in the set, (not to mention how long the DLP lamps last) ....when you DO repair one, and something ELSE fails 2 months later, it makes it look like it "wasnt fixed right the first time" It's a complete customer relations nightmare!
The other possibility "could" be the light engine, but this problem sounds more like the capacitors in the chassis are finally giving out.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 08, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Cook top light stays on
Sounds like the bulbs shorted out the smart board, this happens sometimes when folks change the bulbs without up-plugging the oven.
Mar 30, 2014 | GE Microwave Ovens
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Red light on status comes on and stays on. Husband replaced bulb and still red light. What could be wrong. DLP WD-62525
Several things can cause this but the most common is that the color wheel has froze and needs to be replaced
Dec 21, 2009 | Televison & Video
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
No pic with sound and turn off by itself with a
The red light is a status indicator that means your tv needs to be serviced. Most likely your bulb burned out or failed. You can purchase a replacement bulb online. I have solved a few questions on how to replace a bulb on this site. Check my profile for those posts if you need help with that.
Jul 01, 2009 | Mitsubishi WD-60735 Projection Television
Replaced bulb in Mitsubishi WD-52525 and it still does not work
Press the input/device button and the menu button at the same time. Green LED will blink a two digit code blink 1st digit short pause blink 2nd digit longer pause and repeat. Any number of problems can cause this same symptom.
If the red LED your refering to is the Status LED and not the Lamp LED then you have big problems. A red Status LED indicates no communication from the Format board to the DMD board (light engine). 1/2 the time caps on the format board itself the other 1/2 must send entire electronics package to Mitsubishi.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
