Question about Canon MP610 Photo All-In-One Printer
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize (even though there is no cartridge to recognize).
  • 117 Answers
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Posted on Oct 08, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
We have a X5650 Lexmark printer. The ink cartridges were both replaced with certified cartridges (parts 36 and 37xl) . When installed the printer does not recognize that the cartridges have ink and...
It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
Jan 20, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Ink repair hp c6180
Step one: Reset the printer
CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top coverc00813643.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridgec00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridgec00372273.gif
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contactsc00372274.gif 1 - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridgeIf the error message still displays, replace the indicated cartridge with a new cartridge
Nov 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have replaced the color cartridge and now the printer does not recognize color. Can you please help me on this?
Hello
Turn on the printer and check the LCD screen for messages. If your printer isn't recognizing what you know to be a new cartridge, the "Low Ink" warning will still be on the screen. Press the green "OK" button for now--if you want the message to reset later, just open and close the lid.
Try printing a test page. Sometimes the ink cartridge simply has a faulty chip and the printer cannot recognize the ink levels.
Open the lid via the handle under the copying tray and remove the ink cartridge in question. Check the bottom for the plastic tab. This tab must be removed or the printer cannot recognize the cartridge. Sometimes when the tab is pulled off, a small strip remains, and this can interfere with printing. Hold it in good lighting and use your fingernails or a knife to gently pry off any remaining bits of the plastic tab. Replace the cartridge, close the lid, and print a test page.
Call the store or website customer service where you bought the ink if the above steps do not work Tell them what you tried, the exact error message your printer is giving you, and when you bought the ink. If it's within 30 days of purchase, they probably have a return or exchange program.
Oct 04, 2010 | Lexmark Office Equipment & Supplies
E16 error message for for canon pixma 210
E16 must be "Ink remaining unknown".Press and hold the "resume" button for 5 seconds.
Oct 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Dell 944 all in one - used NON-Dell Print Cartriges - Cheaper
Hi there
Your error message is coming from the Dell Series 5 ink Cartridge. To reset the error message, unplug the printer from the wall. Now remove the power brick from the back of the printer. Wait 60 seconds and then plug everything back in. This usually resets any error messages on the printer. Make sure the Dell Series 5 ink cartridges are intalled correctly by removing them and re-seating them .
Black in left or black side, color in right side or color side
If using a photo cartridge...
Photo cartridge in the black side(left) and color in the color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Sep 13, 2009 | Dell A940 All-In-One InkJet Printer
Replaced all ink cartridges after low ink warning. Since then I get an error message, "ink cartridges cannot be recognized" ok proceed produces an information message to replace ink cartridges. On it goes...
First, are you absolutely sure you have the correct cartridges? Next, have you tried replacing the old cartridges that were originally there, or were they completely empty? Next thought is that your print heads might be dried up. Sometimes regular users can fix this with alcohol wipes depending on your specific model.
Mar 24, 2009 | Epson Stylus Photo RX580 All-In-One...
MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
280 people viewed this question
old marine
old marine
