Question about Whirlpool 24 in. DU900PCD Built-in Dishwasher
Whirpool dishwasher problem
The soap dispenser does not open when it should leaving most of the soap if not all unused!!!
HELP
  • mikekeys59 Mar 03, 2009
    I almost have the same problem, but I find the door slightly opened with most of the soap still inside, in one clump. I will wait to hear from you.
WANT DRY DISHES
Posted on Jan 17, 2009
Soap dispenser will not open
there could be several problems. It could be impacted with dried residue, the solenoid could be jammed or burnt out or the contacts in the timer could be burnt.
Good luck
Nov 07, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
The soap dispenser isn't opening all the way. Therefore it leaves a small amount of soap in the chamber after the rinse and dry cycle. How do I fix it?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 20, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
We are having trouble with our dishwasher. When the cycle finishes the soap remains unused. We tried a second cycle & received the same results.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Dec 24, 2010 | Dishwashers
Soap not fully dispening
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 12, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Smeg Dishwasher SA 620 X-Soap dispenser won't open!
Sounds like the solenoid in the dispenser has failed. Youll need to replace it
Please leave feedback
Thanks
Rob
Feb 12, 2009 | Smeg CSU2001 Built-in Dishwasher
My soap won't dissolve during the cycle.
You are not getting enough water or you are losing the water during wash cycle. Is you dishwasher new or older? How is it plumbed in? If it is plumbed through the floor you will have to put and air gap in to keep the water in it. All tall tub dishwasher have to be plumbed properly.
Jan 05, 2009 | Frigidaire 24 in. FDB635RF Built-in...
UNDISSOLVED SOAP RESIDUE AND
Dispenser door sticking. Run it a few cycles by putting the tablet in the cutlery basket.
Mar 22, 2008 | GE 24 in. GHDA986KSS Built-in Dishwasher
Soap dispenser doesn't open?????
have the same issue were you able to find a solution?
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool 24 in. DU900PCD Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
