Question about Palm Treo 755p Smartphone
Phone and Battery Hot on 755p verizon
Just bought the phone. The battery and phone get really hot when charging, charging takes forever and then the phone doesn't hold the charge...
Hoping this is simply a bad battery? Any thoughts?
  • 59 Answers
Try this link about Treo batteries-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=83,E=0000000000825404717,K=4996,Sxi=13,Case=Obj(28582)
Battery won't recharge-
?St=42,E=0000000000826384196,K=1280,Sxi=19,Case=Obj(30029)
Posted on Jan 08, 2008
What can i do about my cell phone getting very hot while charging?
Need to check Bluetooth and wifi are off.also if the signal bar is weak this will cause phone to hunt for nearest mast continually which uses up battery power.turn the brightness of the LCD down more than usual .if this does not improve battery life get new battery.
Oct 23, 2014 | LG Spectrum VS920 4G LTE Verizon Wireless...
How long should the battery last in my Verizon samsung 4g lte phone?
If your battery only lasts 4 hours tops, it could be defective. Best thing to try is to swap batteries with your son - if your phone lasts longer on his battery, that's the problem. I'd recommend taking the phone back to the Verizon store you bought it from. Also, make a habit of closing out of all apps that you are finished using - apps running in the background use battery as well.
Sep 12, 2014 | Samsung Verizon Wireless 4G LTE Mobile...
Cell not switching on n battery getting hot.if battery is put to charging its not displaying "battery charging" as such cell is not at all working.
Hi,what causes a phone to get hot and kills the battery,is because an IC inside the phone board is faulty (bridging) and a makes the phone to get hot and discharge the battery faster.
You can take it to a skilled personnel for repairs.
Take care.
Aug 20, 2010 | Nokia 6280 Cellular Phone
Phone flashes "verizon" but wont turn on
Take your battery out and see if it feels swollen, this sounds like a classic case of a failing battery, either it is too old and will not charge, it has gotten too hot, or it has received improper voltage.
You need to replace your battery.
Aug 15, 2009 | LG CHOCOLATE VX8500 Cellular Phone
LG viewty ku990 - no battery life and phone gets really hot
Hi
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
Dec 26, 2008 | LG KU990 Viewty
Pink Chocolate battery problem
The problem could be one of two things - the phone, or your charger.
Most likely the problem is with the phone, since it's pretty rare for a charger to cause problems this severe. I would recommend taking it into your carrier's local store and trying to get it replaced.
Jun 26, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Treo 750 p
Personally 10 to 15 minutes is not normal, I have had my 755p battery get hot after a couple of hours of straight talking, but not right away.
I would just take it back where you got it and tell them the problem that you are having and get another Treo. I have owned all of the Treo's ever made and they make great phones.
It does take some getting used to but the pros vs the cons of owning a Treo are much greater. Blackberry has come along way with their phones and if you are used to the Blackberry then the Treo just might not be the phone for you.
To get back to your question if the phone getting hot is normal, no, but it will happen from time to time when talking on the phone for long periods of time.
Hope this helps,
Glenn
Jun 20, 2008 | Palm Treo 755p Smartphone
Treo 755p Frozen
My 755 restarts when I try to get to instant messaging. Also when I try to delete mail.
leaseman
Jun 08, 2008 | Palm Treo 755p Smartphone
Treo 755p phone audio stops working
try doing a hard reset just make sure you hotsync first so you can backup all your information. Always keep in mind the software you have loaded write it down and the website you got them from along with any registration codes. when doing a hard reset you will lose all the information and programs on the phone basically it will take you back to the way you first bought it.
How to Hard Reset a Treo 755 To perform a hard reset/clean wipe of a Treo 755, do the following:
1. Remove the battery cover from the back of the device.
2. Press and hold the power (red phone) button.
3. While holding the red power button remove and replace the battery from the device.
4. When you see the "Access Powered" screen on the device take you finger off of the power button. At this point, you'll be prompted to erase the device by pressing up on the directional pad.
Good Luck I hope this helps with your problem
May 27, 2008 | Palm Treo 755p Smartphone
I have had three SCH- u740 cell phones and all of them burn up battery life
sounds like a short to me. I had a similar problem on a PDA phone the carrier replaced the battery and cured the problem.
Nov 12, 2007 | Samsung SCH-u740 Cellular Phone
Palm Treo 755p Smartphone Logo
242 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
