Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
On our honeywell trolatemp universal minizone zone 1 and zone 2 lights are green. The purge light is flashing. Heat light is red and both thermostats are set at 74 and the temperature inside is 70 degrees, why isn't the furnace turning on?
  • Bill Eller Dec 14, 2011
    The system runs on a 2-5 minute delay. The system will also purge for a few minutes as well. Green lights mean the damper to those rooms are open. Red lights mean they are closed. The yellow light is purge. Set your temp to five degrees above your interior temp and wait about 5 minutes. Hope this helps.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
It should reset itself off purge then system will come on. If not take cover off zone board and press the purge override button.
Posted on Jun 09, 2013
  • Honeywell Expert
  • 252 Answers
Sounds like a furnace problem - the zone control sounds right
Posted on Oct 08, 2009
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
Heat not woking purge light flashing
The flashing light is giving you a code as to what is work... have you tried to recycle the power???
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jan 15, 2011 | Honeywell Electronic Programmable...
Honeywell fx4bnf048 Yellow purge light is flashing slowly. Instructions say sensor failure or sensor not installed...
i have honeywell system and zone 3 is off and purge light flashing and i have heat in all rooms except for my daughters room??? please HELP
Sep 22, 2010 | Heating & Cooling
PURGE LIGHT FLASHING
It is a discharge temperature sensor and should be located in the duct after the coil. It should be just before the bypass damper.
May 08, 2010 | Honeywell Heating & Cooling
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
The Zone 1 (basement) and Zone 3 (second floor; no
On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
Dec 26, 2009 | Honeywell Electronic Programmable...
Just bought a home with a Honewell trol atemp universal mini zone
because it dosent have a duct sensor - should not be a problem
Sep 03, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,674 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
