Question about LG WM-2277HW Front Load Washer
I'm getting the OE code and I've done the the line purge and filter clean a couple of time but I keep getting the error after the wash cycle when the machine try to drain the water I have an LG WM2701H8
  • yadayada
    yadayada May 11, 2010
    what is the code
    President:
  • 1,304 Answers
Try cutting way way down on your soap
front load washers seem to exhibit weird problems when oversoaping occurs
try one load with no soap at all
and then try using 1 tablspoon per load
barring that you may have a clogged pump
Posted on Oct 08, 2009
What is OE error code
The OE error code is related to incoming water flow. Make sure both your water lines are turned on. If your lines are turned on, turn the lines off and then disconnect the water lines. There is a small wire basket filter in each water inlet. Pull out each filter, clean out each filter and then re-insert the filters. Reattach the water lines and turn on the water. Make sure there are no water leaks. This should clear the OE error.
Jul 06, 2014 | LG WM1814CW Front Load Washer
Oe error code
Jun 29, 2014 | LG WM1814CW Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
For LG WM2233HW, Error Code OE. Already check drain hose and filter, all clean. Try different cycles, TUB CLEAN, SPEED WASH. Same error code. No drain.
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Jun 19, 2009 | LG WM-2277HW Front Load Washer
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
166 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
