Question about Refrigerators
Freezer on bottom , pools water freezes eventually spills on to Kitch floor must hammer out froozen ice on freezer floor and remove whats the problem not paying buy cc I read your terms of use and as i said will not put on a credit card and do not want to be cheated.
    President:
  • 1,304 Answers
You have a clogged defrost drain
get out all the ice
take off the back panal
and clear the drain pull the unit out and take off the machine compt panal
look under you will see the defrost tube drain
make sure this is draining properly
once you do that take a flat head screwdriver in make the whole in the tin heat reflector more round
what happens is a thin sheet of water covers that hole and eventualuy builds up...
go back to the back, and ensure the drain is clear i usually take it off and runn water through it
some times ive found a small screw in it from assembly
barring all that
make sure the fill tube from the ice machine is properly installed
but i would tend to think its more of a drain situation
Posted on Oct 08, 2009
  • Refrigerators Master
  • 4,654 Answers
This sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to **** out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze
  • John Tripp
    John Tripp Oct 09, 2009
    I'm misunderstood your meaning of TOS. Are you addressing this to Fixya or something I posted to assist your freezer leaking problem? I have more help topics on this problem if you like and the service is free here at Fixya. Navigating Fixya for the first time may be a little difficult, so I would not concern yourself if you think you are being charged. Thanks, Sea Breeze
My samsung rs2630sh, has water pooling at the bottom of the freezer. Water will also leak out of the until onto the floor. the ice buit up so much had to break it up just to get the bottom tray out. Any...
I have the same problem. Water from the defrost coil is not running out the outlet, but freezing in the defrost "catch" pan and outlet tube. Once water freezes, then water from subsequent defrost cycles, runs into the freezer floor and eventually out to the front or side. I don't have a permanent solution, but you can take the inside panel off with the four screws and see the problem. Chip out the ice dam and clear pathway with very hot water. I have read that lowering the freezer temp may prevent. Open to new ideas or permanent solutions. Good luck!
Mar 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
WATER FREEZES ON THE BOTTOM OF THE FREEZER
I have an LG armoire style fridge/freezer and it had lots ice in the bottom and would eventually drip onto the floor. The problem was with the defrost controller. The moisture that enters the freezer when it is opened condenses and freezes on the freezer coil/fins. There is a heating element that sits under this coil which gets turned on by the defrost controller to melt the frost/ice. As the frost/ice melts it drips into a metal tray which channels the water to a drain hole to have it drop into the drip tray underneath the unit for it to evaporate. The problem is that the before the water has time to leave the freezer, it freezes thereby plugging up the drain hole and thus causing subsequent defrost cycles to have the water flow into the bottom of the freezer where it freezes. Eventually the bottom of the freezer fills up with enough ice for the melted water to flow onto the floor. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Sep 22, 2009 | Maytag Refrigerators
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
How do you unclog the condensation drain on a GE gss25wgma model refrigerator? have water pooling and freezing on the freezer floor, spilling out onto the floor within days after removing it. Thanks!
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Jun 22, 2009 | GE GSS25JFM Side by Side Refrigerator
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
WATER POOLIN AND FREEZING AT ON FLOOR OF FREEZER. ICE MAKER NOT HOOKED UP
you have a blocked drain remove back freezer panel
at the bottom you will find a lot off ice remove it with hot water and clean drain hole the pop is the ice cracking
Apr 17, 2009 | Refrigerators
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
