Question about Garden
Problem is with sn70 nail gun. has been idle for some months and on application appears to have problem in the valve assy behind the trigger. first pull there is movement of I think the valve spool ,next time a blast of air from the back plate rear of the valve mentioned. there are some radial holes at the rear of the valve assy and air is exhausting from this locaton. Have you an assy drg of this valve.
  • biduelli Oct 13, 2009
    Having contacted the Senco website, senco was very helpful by sending complete service details, drawings ,parts lists etc.
    I will be able to fix the problem as I now have detailed information on the operation of the nailgun.
    President:
  • 1,734 Answers
Hello - I'm going to guess that it is "skipping nails" , right ? First you need to purchase the rebuild kit, then pull it apart and replace the O-rings and gaskets and stuff. If you're not very handy you may want to take it to your local "Senco Authorized repair center" I know the kits are on E-Bay pretty cheap, To bring it in you might be looking at as much as 50-75 bucks ?? Heres the Senco site, click on "find a dealer" http://www.senco.com/ And you can download the manual here http://www.senco.com/con_rem/pub_chart.aspx
Posted on Oct 08, 2009
I dropped my SN70 on the nose and ever since then it will not fire. It hisses from the trigger when it is pulled.
The firing pin must be depressed all the way in by the safety foot in order for the gun to fire. It will work again after you adjust the safety. To test the gun, remove the trigger, and the nails and very quickly depress the trigger pin all the way in. Good luck
Oct 31, 2015 | Senco Air Tools & Compressors
With 90 # air and PC nails. When I pull the trigger nothing happens. No air noise, no nailing, no movement - just dead. It's been oiled every use.
Most likely stuck trigger valve. Easy to check. Remove nails, remove trigger to expose the firing pin of trigger valve. Connect air and very quickly depress the firing pin all the way in. If the gun fires , adjust the safety to depress the trigger valve completely. If the gun does not fire, replace firing valve, or remove and check /lube o-rings in valve. Good luck
Jul 11, 2015 | Air Tools & Compressors
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
Mar 29, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
I have a Senco SN70 framing nail gun. The gun
One question is do you regularly put oil in the gun? Also you need to make sure that the screw holding the 'clip' near the barrel is tight and not loose. These are the 2 main problems when a gun is misfiring.
Oct 02, 2013 | Senco Air Tools & Compressors
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
DeWalt D51823 nailer shoots continusously when plugged into air hoswe
Shooting continusously caused by worn orings in the trigger valve and in the gun.Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer (white plastic). Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. The trigger valve also has vinyl orings on the trigger pin. You could try replacing the orings but hard to find . Pin uses 2mm x 1.5mm. The orings on the inner valve should fit snuggly on the outer contact surface. If the valve just falls out the the body, the orings are too loose or the body is worn. I would just replace the trigger valve to be safe, however repaired works ok if you can find the orings. Trigger orings do not come in the kit. I would also remove the nails after each use and only reinstall them after air is connected and gun seems to work as it should. The Good luck with your repair.
Dec 23, 2012 | Air Tools & Compressors
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
GUN DOES NOT FIRE FOR SEVERAL ATTEMPTS--even though gun is pressed firm against work---just had unit serviced and trigger valve replaced-----any suggestions? thanks joel
Remove nails and remove trigger to expose trigger valve pin. Place nose of gun against rubber pad or old coiled up air hose to absorb impact of driver and with very quick and deliberate motion press in trigger pin. If gun fires, then problem is with safety foot not pushing trigger pin all the way in (or worn trigger). Make adjustment as needed or replace faulty parts. If gun still does not fire, then likely problem is with headvalve. If headvalve orings are leaking, gun will not fire. Test for leaking orings as follows. Remove head and remove headvalve, apply silicone paste lube (plenty) to all orings and where orings contact. Assemble and do test above. If gun fires then surface where orings contact is allowing air to leak(smooth with very fine sandpaper if scratched).
Mar 13, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
