Question about Zenith B27A11Z 27" TV
WHEN I TURN THE TV ON IT IMMEDIATELY SHUTS OFF....THEN, I CAN'T TURN IT ON UNLESS I UNPLUG IT FIRST. IT SHUTS OFF IMMEDIATELY AGAIN.....AND SO ON!! I WAS THINKING THAT MAYBE THERE WAS A ''FUSE'' OR SOME TYPE OF SHUT OFF FOR A SHORT CIRCUIT OR SOMETHING LIKE THAT. IT IS AN OLDER MODEL PROBABLY
  • 379 Answers
This sounds like a serious overload of the power supply circuitry - as the TV tries to start up, it is sensing an overload and therefore shuts itself down to protect itself (and you if it overheated).
Primary causes of such overloads in older TVs is a fault in the power supply circuitry itself, or a fault in the line output circuitry (the bit that generates the high voltages TV's use, and also the bit that scans the picture left to right).
Both types of fault require expertise and test equipment well beyond DIY level, to diagnose and repair.
Suggest you call a repair shop who should give you a free estimate as to likely cost of repair. Then you can decide if it worth it or not.
Posted on Oct 08, 2009
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
32 LCD, Shuts off, power light flashes 7 times. Never stops. Will not turn back on unless I unplug. Works for a few mins and shuts off again.
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 22, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Tv will not turn on
There is a fault condition in the TV. Safety circuit shuts it down.
Check with the authorized service center.
Apr 16, 2010 | RCA L42WD22 42 in. LCD Television
TV shuts off after 5 minutes.
ours did that we had to replace the lamp
Jul 21, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Tv shuts off for awhile then i can turn it back on immediately
hitachi is known for its problems and the best solution is to call a repairman out to repair it properly.i know thats not much help but its the only sure way to fix it and fix it right
Jan 21, 2009 | Televison & Video
Panasonic projection tv (shuts down)
check r517 on the power supply board if it is burnt or damaged replace it with a + or - 5% 10K 1/4 watt resistor this has been a problem in other units.
Oct 03, 2008 | Panasonic PT-47WX51 47" Rear Projection...
I have a Pan. pt 51g30t shuts off immediately
The most likely part is a fault with the convergence board and the main power supply. In many sets like yours when an amp module on the convergence fails the picture will bend out of shape and cause the power supply to shut down
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Panasonic PT-51G44 51" Rear Projection...
TV will not come on
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Jan 03, 2008 | RCA 32F531T 32" TV
Zenith B27A11Z 27" TV Logo
251 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
