Question about Breville Die Cast 800ESXL Espresso Machine
Espresso pump motor won't turn on
Could it be the capacitor, or perhaps a fuse
    President:
  • 1,618 Answers
That is very likely. The capacitor might be damaged, check for signs of a burnout.
Posted on Oct 08, 2009
How can I fix my Keurig Coffee maker? It pumps water from the time it is turned on 'till it indicates add water. Any suggestions?
either the heating element has failed or a thermal overheat trip device or thermal fuse has failed
you need to use a meter and see if the heating element is getting AC power
perhaps the pump actuator usualy a relay or a triac device has failed and gone short or fused contacts ....
hard one to diag from words only
Dec 04, 2014 | Keurig Coffee Makers & Espresso Machines
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
DAB Jet 62 won't pump
U might've burned the start capacitor also. If u don't see one on the exterior,check inside the end bell (cap) of your motor. Do u hear the motor hum? If not there a likelyness u burned ur motor
May 26, 2017 | Plumbing
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Washer pumps but half the time it won't spin unless you give the basket a little push. I use a small magnet to keep the lid relay closed. Once I give the basket a little push, the washer starts to...
Quite likely the spin motor is a capacitor start type motor and has a capacitor to start it (by placing a winding slightly out of phase with the rest of the motor in turn encouraging the movement of the motor). When it reaches about 200 RPM the capacitor is disconnected and runs without it.
Maybe the start capacitor is faulty or the internal switch/electronic control is faulty?
Aug 30, 2011 | GE WPRB8050D Top Load Washer
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
Model SP15921TLNP 1HP pool pump. Only had 1 year. We have had local quick on off power outages in this area. Now Pump does nothing. Using tester have power into the motor. I think may be capacitor but I...
Capacitor should be inside cylindrical cover on motor's side; simplest test is to replace it. If motor humms but won't turn maybe bad capacitor, stuck bearing (turn by hand) or bad/dirty centrifugal switch contact. If no humm at all, may have burnt internal neutral wire.
Jul 08, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
After some excellent advice most of my problems with my airmaster 15/50 3hp compressor have been solved, but I still have one problem,the tank fills up to 150psi and swithes off,when I use the air and it...
The piston in the motor has a larger "problem" bucking up against the 100 PSI of backpressure already in the tank. Thus, the larger amperage required to start the compressor motor when air is in the tank. Does the compressor motor have a starter capacitor? Perhaps the capacitor has failed...
Mar 26, 2009 | Air Tools & Compressors
Breville Die Cast 800ESXL Espresso Machine Logo
999 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
