Question about Plumbing
Changed out tekmar 353 Mixing control with 356 control the mixing pump will not start.
SOURCE: no mixing
Sometimes it depends on the temperature of your ingredients. We have had a B&D machine for over 13 years now and it makes wonderful loaves of bread and rolls and pizza dough...you name it.
However the new B2300 was on sale at half price this week and we decided to get a new one because of the extra sizes it makes.
I expect this one works the same as the old and it takes a while to "think" about what it is doing. I hope your loaves still turned out nicely. But sometimes there IS a bit of experimentation to get the mixes just right.
While I am here, I will give you a tip. If the paddles get stuck in the container, do NOT try to force them out of it. Instead, put some warm water in there and just forget it for a while...maybe an hour and they will just lift right out as slick as can be. Otherwise you can break those suckers and they are a devil to get hold of new ones after a year or so.
Posted on Nov 29, 2008
clyde2j2
  • 137 Answers
SOURCE: bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Posted on Mar 28, 2009
  • 125 Answers
SOURCE: water/oil mixing in 22r engine
yes it can mix, also check the timing cover for rubs from the timing chain. this is the common problem with 22r. many mechanics will tell you its the block but they are just trying to make money.
Posted on May 02, 2009
simontricket
  • 235 Answers
SOURCE: oil mixing with Diesel and car emits white smoke.
The copper washers on the bottom of the injectors can give this fault if they are not renewed when the injectors are replaced .
If you have changed these allready and made sure you pulled them down exactly as the manual says in 3 stages then you may have a bad injector - see your Isuzu dealer .
Posted on Jan 21, 2010
Magaiver
  • 707 Answers
SOURCE: Hello, Hot
Yes the mixing valves do wear and give out........I had to put a micron filter in the input line to the hot water tank and solved the promlem for around 8 tears now. knock on wood....Hope this helps.
Posted on Aug 13, 2010
15w40
Hi John, These days most oils are formulated to be used in both petrol and diesel engines but those formulated specifically for diesels should not be mixed. If your talking of a top up I suggest a flush with a good quality chemical and a lub service. If you have had a service carried out and changed the type of oil the same applies. Mixing oils can cause fast sludge build up which can block the filter, oil pump and galleries. These days most oils are designed to run both types of engine, but mixing is neve a good idea. Regards John
May 01, 2013 | Cars & Trucks
Model 1650
Black and Decker machines go through a warm - up phase and don't start mixing right away. If your machine still hasn't started mixing after 30 minutes contact breadmachineshelp.com
Jan 06, 2013 | Black & Decker Bread Machine
Wont start mixing
Which program are you using, white, wheat, french, etc.? Black and Decker bread makers I think ever start right away. They warm the oven gently for awhile. If your machine hasn't started mixing within 30 minutes of pressing start, only then do you have a problem. That is true for the Wheat program for sure.
Dec 23, 2012 | Black & Decker B1561 Bread Maker
Comet tw 5050 mix oil and water
what you have is a bad seal or a crack within the pump crack more common if any water was left in it during the cold winter
Jun 22, 2012 | Comet Pressure Washer Tw5050 Triplex Pump...
Hi, i have automatic passat 1999 model and recently water happens to get into the gear box and it control board, i experiences a boom sound anytime the gear is changed, the oil has been changed by the...
If no external leak and the transmission fluid colour looks white, the problem belongs to the automatic gearbox oil cooler. The oil cooler has broke mixing the gearbox oil and coolant causing this milkshake. It's a small radiator core type oil / water heat exchanger. It is cracked inside and transmission oil is mixed with engine coolant. Because the transmission oil pressure is greater than engine coolant pressure, the transmission fluid level drops. See also the coolant colour inside recovery coolant reservoir inder bonnet! It could be like this:
The automatic gearbox oil cooler type oil / water heat exchanger (oil cooler):
In the picture above the transmission oil pan was removed for oil filter replacement.
May 05, 2011 | 1999 Volkswagen Passat
Hello, Hot to very warm water comes out of the regular COLD water faucets throughout the house for about 45 seconds whenever the COLD water faucets are opened. I suspect that the thermostatic...
Aug 12, 2010 | Home
Engine oil is mixing with coolant
You need to find it, and not run it, as coolant in the oil destroys things fast. Pressure test your coolant system to find a leak. You might be looking at head gasket, or even water pump seal area to start.
Jun 22, 2010 | 2005 Honda CRF 250 R
Think my oil pump going the light come on an rattling started then i got oil changed an added lucus it doing the same thing how hard is it yo get the oil pump out
Get the oil pressure tested....
If you hear rattling, it's probably low oil pressure, but it could be the pump, or if your bearings in the engine are worn badly, that will cause it also. (From antifreeze mixing with oil)
Jan 08, 2010 | 2003 Dodge Durango
Water/oil mixing in 22r engine
May 02, 2009 | Toyota Corolla Cars & Trucks
Plumbing Logo
352 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
