Question about Insignia NS- 27" TV27 TV
Insignia Plasma 27" TV
About a few months old. The inputs keep changing by themselves. I tried changing the settings but nothing seems to work. Help somebody.
I have the same problem... i think it happend when i accidently plugged left audio to white component on my dvd... HELP!!!!
Posted on Jan 25, 2008
How do I set up a PS2 on an Insignia NS-40D510NA15 flat screen tv?
That seems like all you should have to do. Are you selecting the correct Input Source on your TV???
Oct 03, 2014 | Sony PlayStation 2 (PS2) Console
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Dec 29, 2010 | Televison & Video
I have 42 nec plasma when i turn on work normaly but after seconds picture became dark
Have you tried changing the input? Meaning, as soon as you power the screen on, press the "input select" button then wait a few seconds if nothing comes up press it again, do this until you find your connection and you should be set. This problem seems to keep coming up with this particular Plasma, so I guess I'll keep on answering. Good Luck
Jan 06, 2010 | NEC PlasmaSync 42MP2 42 in. Television
When the T.V. is turned on, nothing appears on the screen but there is sound
TV-3940-01 upgrade is the kit you need. However people are waiting upwards to 6 months to receive it if at all. You have to order it from sears or haier.
Mar 16, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
I own insignia 27" lcd input vedio keep changing none stop
Check to see that none of you manual buttons are sticking or stuck, especially INPUT !
If none are stuck and your set is still under warranty please return it.
If not under warranty I would suggest taking to a local service center that is familiar with Insignia.
Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia 27 inch lcd tv gets no video or audio
the most common item that fails with all LCDs is the power invertor or power supply, and that sounds like what your set is needing is the capacitors have possibly failed on the Invertor
Jun 28, 2008 | Televison & Video
No audio on my samsung FPT5084
Jun 06, 2008 | Samsung FPT5084 50 in. Plasma HDTV
Insignia 27", no picture, clicks on and off by itself
Had same problem with a 24" Insignia. Took it back to BestBuy who sent it in for repair. Repair ticket listed problem as a couple of "cold" solder joints. Apparently correct as set has worked fine ever since I get it back.
Nov 13, 2007 | Insignia NS- 27" TV27 TV
On a LCD TV either the lamps might not be coming on or there is a video problem. If unplugging it for 30 seconds then trying again doesn't bring it back then expert help is needed.
Apr 25, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia NS- 27" TV27 TV Logo
162 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
