Question about Ovens
It's a whirlpool RBD245 double oven about 4 years old. I was watching the Dodgers and Cardinals tonight and the think just started beeping. I got up and went to it and saw no display on the LED panel. The doors open, the oven lights go on, the pads "beep" when they are touched, and no cirucit has been tripped - everything else electronic in the kitchen works. When I touch and hold the start button I get two beeps followed by 3 quick beeps but no lights. I'm reading in other responses that it may be the control panel. Any input would be greatly appreciated. Thanks
  • ckbrewster Oct 08, 2009
    Will do. Thanks.
  • 10,515 Answers
Try to unplug and plug in the Oven and see if that would reset the control board.If that doesn't work you want to check the wiring to the control board and make sure that nothing has come unplugged.
If everything looks ok, then you want to look into replacing the control board.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 08, 2009
Whirlpool double electric oven model D245. Buttons beep when pressed, oven lights up when door opened. Cost to repair control board?
that isn't a good model number,how old is this oven?if it's over 15 years you can't get parts for it most likely,when you find the model number off of the oven go here and see if you can still get parts for it.
https://www.searspartsdirect.com/model-number/GMC275PDB07/1198/0125400.html
Sep 27, 2017 | Whirlpool Ovens
How do I clean the lower oven for model rbd245
If you don't have a self cleaning oven, then use an SOS pad to remove any baked on stuff. You may want to scrape the heavy stuff first so that the SOS pad will be more effective.
Jan 26, 2015 | Whirlpool RBD305PD Electric Double Oven
KitchenAid Double Oven LED Blank
These ovens are made by Whirlpool. The electronic control board is notorious for going bad. If it is the one I am thinking about it is probably no longer available and will need to be rebuilt. I have had good success with Corecentrics Solutions. A google search will bring them up. I sent off the board and a rebuilt one arrived in about a week. Much cheaper than the original board too.
Nov 26, 2013 | KitchenAid Ovens
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 24, 2013 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Error codes/oven functionality
Hi this sounds like the electronic clock has failed. Either replace or bypass possible.
Oct 22, 2017 | Whirlpool RBD245PRS Stainless Steel Oven
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Ovens Logo
135 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
