2000 Chevrolet Cavalier Logo
Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blown head gaskit need to remove head and replace with new ong
  • Marvin
    Marvin May 11, 2010
    what is ong???
Greg Bernett
Level 3:
  • Chevrolet Master 2,993 Answers
  • Posted on Oct 08, 2009
Greg Bernett
Chevrolet Master
Level 3:
Answers
2993
Questions
Helped
2782244
Points
13428
2.2L (VIN 4) Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Relieve the fuel system pressure.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • Accessory drive belt
    • Air cleaner outlet duct
    • Engine mount
    • Intake manifold
    • Exhaust manifold
    • Engine Coolant Temperature (ECT) sensor electrical connector
    • Power steering pump
    • Radiator inlet pipe
    • Spark plug wires
    • Rocker arm cover
    NOTE Whenever valve train components are removed, keep them in order for installation purposes.
    • Rocker arms and pushrods
    • Lifters
    • Alternator rear brace and the alternator
    • Ignition coil assembly
    • Accessory bracket
    • Spark plug wires
    • Cylinder head bolts
    WARNING Two sizes of bolts are used; note the location of each.
    • Cylinder head
  5. Inspect the cylinder head and block surface for cracks, nicks, heavy scratches and flatness.
Cylinder head torquing sequence—2.2L (VIN 4) engine
  1. Install or connect the following:
    • Cylinder head with a new gasket and new cylinder head bolts. Torque the long bolts, in sequence to 46 ft. lbs. (63 Nm) and the short bolts to 43 ft. lbs. (58 Nm) plus an additional 90 degree turn on all the bolts.
    • Lifters
    • Pushrods and rocker arms. Torque nuts to 22 ft. lbs. (30 Nm).
    • Rocker arm cover. Torque the bolts to 89 inch lbs. (10 Nm).
    • Spark plug wires
    • Accessory bracket
    • Power steering pump. Torque the bolts to 22 ft. lbs. (30 Nm).
    • ECT sensor electrical connector
    • Exhaust manifold. Torque the nuts to 118 inch lbs. (13 Nm).
    • Alternator. Torque the bolts to 37 ft. lbs. (50 Nm).
    • Intake manifold. Torque the bolts to 17 ft. lbs. (24 Nm).
    • Engine mount. Torque the bolts to 55 ft. lbs. (75 Nm).
    • Negative battery cable
  2. Refill and bleed the cooling system.
  3. Start the vehicle and inspect for leaks.
  • 1 more comment
  • Greg Bernett
    Greg Bernett Oct 08, 2009
    2.3L & 2.4L Engines
    CAUTION
    The fuel injection system remains under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
    CAUTION
    After relieving system pressure, a small amount of fuel may be released when servicing fuel pipes or connections. In order to reduce the chance of personal injury, cover fuel pipe fittings with a shop towel before disconnecting, to catch any fuel that may leak out. Place the towel in an approved container when disconnect is complete.
        Disconnect the negative battery cable.
    CAUTION
    Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant.
        Drain and recover the coolant into a suitable container.
        Disconnect the heater inlet and throttle body heater hoses from water outlet.
        Remove the exhaust manifold.
        Remove the intake camshaft housing and lifters, then remove the exhaust camshaft housing and lifters.
        Remove the oil fill tube.
        Remove the throttle body-to-air cleaner duct.
        Disconnect the power brake vacuum hose from throttle body.
        Remove the throttle cable bracket.
        Remove the throttle body from intake manifold, with electrical harness and throttle cable attached. Position it aside.
        Disconnect the MAP sensor vacuum hose from intake manifold.
        Remove the intake manifold brace.
        Disconnect electrical connectione from the following sensors: MAP sensor, intake air temperature sensor and EVAP canister purge solenoid.
        Disconnect the upper radiator hose from water outlet.
        Detach the coolant temperature sensors connectors.
        Unfasten the cylinder head bolt, then remove cylinder head and gasket.
    To install:
        This is an aluminum cylinder head and must be treated with care. Do not use abrasive pads to clean the cylinder head or block surfaces. An abrasive pad may damage the cylinder head and block. GM saye that abrasive pads should not be used for the following reasons:
            Abrasive pads will produce a fine grit that the oil filter will not be able to remove from the oil. This grit is abrasive and has been known to cause internal engine damage.
            Abrasive pads can easily remove enough metal to round cylinder head edges. This has been known to affect the gasket's ability to seal, especially in the narrow areas between the combustion chambers and coolant jackets. The cylinder head gasket is likely to leak if these edges are rounded.
            Abrasive pads can also remove enough metal to affect cylinder head flatness. It takes only about 15 seconds to remove 0.008 in. (0.20mm) of metal from the cylinder head with an abrasive pad. If the cylinder head flatness is out of specification, the gasket will not be able to seal and the gasket will leak.
        Use a razor blade gasket scraper to clean the cylinder head and cylinder block gasket surfaces. Be careful not to gouge or scratch the gasket surfaces. Do not gouge or scrape the combustion chamber surfaces. Use a new razor blade for each cylinder head. Hold the scraper so the razor blade is as parallel to the gasket surface as possible. Do not use any other method or technique to clean these gasket surfaces. In addition, GM warns not to use a tap to clean cylinder head bolt holes.
        When working on an aluminum head, do not remove spark pluge from an aluminum cylinder head until the cylinder head has cooled. Always clean all dirt and debris from the spark plug recess area. If the spark plug opening threads are damaged and NOT restorable with a Thread Chaser, replace the cylinder head. GM DOES NOT approve of the installation of thread inserts into the spark plug openings on this engine. If threads are installed into the spark plug openings, severe engine damage will occur.
        Clean all the gasket surfacee completely. Clean the threads on cylinder head bolts and be sure all bolt holes are clean and free of debris. New bolts are recommended.
        Place a new cylinder head gasket on the block. Do not use any sealing material.
        Carefully place the cylinder head on dowel pins, being careful not to disturb the gasket.
        Apply a small amount of clean engine oil to the threads of the cylinder head bolts, and install finger-tight.
  • Greg Bernett
    Head bolt torque sequence-2.3L and 2.4L engines
        Tighten head bolts in sequence. Tighten bolts 1 through 8 to 40 ft. lbs. (65 Nm);, then, tighten bolts 9 and 10 to 30 ft. lbs. (40 Nm). Turn all 10 bolts an additional 90 degreee ( 1/4 turn) in sequence.
          Attach the coolant temperature sensor connections.
          Connect upper radiator hose to coolant outlet.
          Install manifold brace and tighten to 19 ft. lbs. (26 Nm).
          Attach all sensor connections.
          Connect the MAP sensor vacuum hose to intake manifold.
          Install throttle body to intake manifold, using a new gasket.
          Install accelerator control cable bracket to the throttle body, and tighten the bolte to 106 inch lbs. (13 Nm). Tighten the nut to 19 ft. lbs. (26 Nm).
          Install the throttle body-to-air cleaner duct.
          Install oil fill tube, tighten attaching bolt to 71 inch lbs. (8 Nm).
          Install the liftere and camshaft housing.
    1. Greg Bernett
      Exploded view of the camshaft housing cover mounting-2.3L and 2.4L engines
          Install the exhaust manifold, then tighten the exhaust nuts to 26 ft. lbs. (35 Nm).
          Connect negative battery.
          Fill coolant system and bleed off air from system. An oil and filter change is recommended.
          Check and verify that vehicle has no coolant or vacuum leaks.
    Golf 5 bkd engine head gasket replacement
    open the head and remove old gaskit packing and apply resibond tube and apply new gasekit packing.
    your engine will work properly
    1helpful
    How to replace cylinder head on 1996 RAV4
    William, Could not a lot on your particular engine, links below to show the basics on removal/install of cylinder head. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    TOYOTA AVENSIS ENGINE REPAIR BLOWN HEAD GASKIT
    How to replace the cylinder head gasket on 96 Toyota Camry 4 cylinder
    Replacing the head of VVTI celica engine 2000 2005
    How to change head gaskit 2003 vr6
    if you do not have exsperiance or have the tools for it.
    go to a garage.it will cost you double cause its an delicate,
    job .that can go easly wrong.you have to drain all the water.remove,
    all tubes -airfilter-carburator-valve cap.you need special tool to untighted the bolts from head gaskit in the wrigh order.get the head carrefully off.the head must be checked in the garage cleaned flattend.
    put the new gaskit in the wright way back.then the head bolts must be tighten also in the right order and tension.put all parts back fill the cooling and get the air out the radiator.also the new has to rodate for atleast 500 km.there are some books or manuel how to do it.
    Building up preasure in radiator resultin in losing water. 1994 JETTA3
    most likely your head gaskit is blown how to make sure
    when engine is cool open the water cap and fill it to the end
    ask someone to start if the water sucks inn gaskit is ok
    if the water jumps out gaskit is gone get the gaskit changed
    3answers
    HOW TO FIX A BLOWN HEAD GASKIT?
    Buy a gasket kit for the upper end. Remove the valve cover intake and exhaust manifolds. Remove the head bolts. Remove head and clean up block from old gasket material. Take the head to a machinist and make sure that it is not warped. If it is warped either replace the head with a new one or have it machined true. Install new gasket and get torque specs with new head bolts and follow torque sequence using the correct torque specs. Clean exhaust, intake and valve cover of old gaskets. install new gaskets and torque according to specifications.
    Head gaskit need replacing.how...
    You have either a one-of-a-kind car or you are wrong on the year or model. Fairmont didn't extend beyond 1983.
    If you have no experience working on engines, I recommend you buy the Haynes manual for the car:
    1978-83 Fairmont
    3helpful
    White smoke cuming out tailpipe 3400 v6
    I would almost bet you have a blown head gasket or a cracked head. White smoke at the exhaust, loosing coolant, moisture on the underside of the oil fill cap, and on the dip stick are all signs of a blown gasket. The fact that there is no coolant in the oil does not mean it does not have a blown gasket. To find out for sure remove all spark plugs, disconnect the coil wire, and then run a compression test on all cylinders. If you find one or more with low compression you have a blown gasket. Do not drive this car any longer until you get this repaired. Serious engine damage will occur if you continue to drive it.
    2answers
    Renault clio over heated stoped dead/head gaskit
    is the oil/water a milky colour? if so, then yes, your head gasket has blown
    Top Chevrolet Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    john h
    Are you a Chevrolet Expert? Answer questions, earn points and help others
