Question about Yamaha Portable Keyboard
How do I do a factory reset on a Yamaha Portasound pss-688
  • 2 more comments
  • patrickmcb20 Oct 08, 2009
    I have done so as specified in the owners manual, all it does is reset memory spaces. I need to total reset or reinitulization as some of the functions are not working
  • yadayada
    yadayada May 11, 2010
    call the maker of the board.
  • yadayada
    press the reset button
2 Suggested Answers
joedirty
  • 158 Answers
SOURCE: one of my keys on my yamaha portasound keyboard is
Sounds like you have a great system,heres a link you can call customer support for a relacement key or a service locationkeyhttp://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail.html?CNTID=451442&CTID=205100
Posted on Oct 20, 2009
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
1) Press the [UTIL] button.
2) Press the [PAGE DOWN] button until the 'Factory Set' screen appears. The message 'Factory Set' will begin flashing on the LCD.
3) Press the [SAVE/ENT] button. The LCD will display the message prompt, 'All data will be lost, Are You Sure?'.
4) Press the [SAVE/ENT] button again to complete the Factory Reset procedure.
Dec 31, 2017 | Yamaha Music
What are the notes on Yamaha porta Sound Voice Back PSS-270
I assume your looking for the manual? if so, go to this page and follow the links. http://download.yamaha.com/
Aug 01, 2015 | Yamaha Music
How do I get the white keys on my Yamaha Portasound PSS-470 to play if there are batteries in it?
If it works with a power adaptor then it should work with batteries.
The power adaptor will need to be unplugged.
The batteries will need to have charge.
The batteries should be connected the correct way around.
If all of the above is correct then there is an internal problem that will require investigation.
Dec 28, 2014 | Yamaha Music
L am looking for PSR 620.yamaha keyboard.it is a musical instrument. l want to get the manual.
http://music.manualsonline.com/manuals/mfg/yamaha/psr620.html there you go please give me some thumbs up!
May 10, 2011 | Yamaha PSRS550B Workstation PSR-S550B...
I have an old Yamaha PSS-595, with no sound on the left channel, either through the main speakers or the headphone socket. Is there an easy answer to this?
It appears that your keyboard has slider for volume control. This is likely a stereo control with two wipers. If one wiper has worn that would cause the problem.
One could sray a TINY bit of CRC226 available at Home Depot in the electrical department into the volume pot and see if it can be restored... USUALLY if these total go dead on a channel they will NOT restore.
If that doesn't work, take it in for repair.
Sep 12, 2010 | Yamaha Music
The Sustain pedal does not work.
When push comes to shove, a factory reset never hurts.
Assuming you'd like to proceed with a factory reset, follow these steps:
This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
1) Press the [UTILITY] button.
2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
5) Press the [EXIT] button to return to the Utility Mode.
Oct 14, 2017 | Yamaha Full-Size Keyboard
Hola,tengo un yamaha portasound PSS-290 que no funciona, necesitaría el diagrama del circuito para repararlo.Gracias
Just to help I can translate this: Hello, I have a Yamaha Portasound PSS 290 which does not work. I need a circuit diagram to repair it, thank you.
Apr 16, 2010 | Music
One of my keys on my yamaha portasound keyboard is broken
Oct 20, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha PSR keyboard won't power up
Unfortunately, I only have schematics for PSS-560 and PSS-570. If I remember correctly,with the parts side facing up, there should be a parts orientation printed on the circuit board. It will look like 2 black bars side by side with one of the black bars thicker than the other. If you got an exact replacement with the correct pin out the metal piece on the part that the black piece is mounted to with the 3 pins facing down towards the parts side of the circuit board should line put with the black bar lines on the circuit board. I hope this makes sense. Please get back to me. I had one of these keyboards laying around in my parts bin but stripped it because all the keys were broken and as they come in one strip asnd have to be ordered specially, I didn't bother keeping it. I may still have the circuit board somewhere.
Apr 15, 2009 | Yamaha Music
Yamaha Portable Keyboard Logo
190 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
