I have an ASRock mainboard in my computer, the CPU is an AMD Athlon 2000+ 20GB HD, DVD burner. Linux Mandriver OS.My problem is the computer does not always start up, HD light comes on and stays on on power up, sometimes takes several power ups to start
Those problems are the worst. Make sure your motherboard is set to report all errors.Try disconnecting everything from the motherboard adding them back one at a time. Try just the video card, hard drive and once piece of memory and see if it starts up normally. If you can't find anything there, try running a memory test program. Memtest86 and Windows memory diagnostic (by Microsoft but doesn't need Windows to run it). If it finds errors replace the memory.
Mobo Samsung Harappa-12 can I have a manual pls? pdf or something my email add is...
(More)
Mobo Samsung Harappa-12 can I have a manual pls? pdf or something my email add is private_demon@yahoo.com I can't connect front panel leds.
come posso aggiornare il bios ?ho un processore sempron 300+ e una scheda asrock k7s41gx,se metto un...
(More)
come posso aggiornare il bios ?ho un processore sempron 300+ e una scheda asrock k7s41gx,se metto un hdd ata lo riconosce ma nn mi fa fare nulla , se metto un pata nn lo vede . la ringrazio anticipatamente
fica aparecendo uma tela com algumas especifica?§?µes da placa e trava, n?£o...
(More)
fica aparecendo uma tela com algumas especifica?§?µes da placa e trava, n?Ło reconhece o hd , n?Ło entra na tela setup.
