Question about Panasonic Televison & Video
Panasonic Model#:CT27SF11S Chassis# : AEDP23A Thin Horizontal line and sometimes when tapped it comes back to normal
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Picture goes to one thin horizontal line in middle of screen
There is a bad solder connection in the vertical sweep circuit. if you know how toi solder, go and find the vertical output IC and resolder that first.. but if you have no solid state electronic repair experience, please find a trained tech to assist you in this repair, as if you wait it may end up costing you double of what it would now, so haveit done ASAP. Good Luck Please do not forget to rate this one.
Posted on Oct 16, 2006
joust
  • 7 Answers
SOURCE: thin horizontal line
Thats almost definately bad solder connection. look at solder joints for cracks around teh lead. better yet, suck outold solder and put in new on any connections that have anything larger than a standard resistor lead. yoke plugs, tuner, etc
Posted on Jan 24, 2007
SOURCE: Thin Horizontal Line on TV screen
I had the same problem on a 36" Hitachi TV about 7 years old. After reading comments on this and other pages I went and bought a soldering iron not knowing what I was going to do with it.
After trying to find a loose connection with the power off- with no success, I then tried with the power on. Not the smartest move, but I was able to find the problem.
If you follow the colored wires (blue, green, red, yellow) from the back of the tube they will come together at a connector that plugs into a card at the bottom of the set. That connection was no secure. Since reseting that connection I have had the clearest picture since puchasing the TV new.
I am sure it is obvious that I don't have an electronics background, and I don't have an explaination as to why this worked. I just know it did. I hope this helps someone.
Posted on Sep 20, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Panasonic TC-P42C2 Horizontal Lines in Picture
problem could also be inside the display panel.
Jun 07, 2012 | Panasonic Televison & Video
36' toshiba with red screen and glowing horizontal lines.
Bad connections on red drive transistor on crt module. Resolder all connections on crt pcb.
Nov 25, 2011 | Televison & Video
HP nx7000 display sometimes still or sometimes flickering horizontal lines then goes and says blank
It appears the video cable connector needs to be seated properly, it may be loose. The connector would be located near to bottom of the screen on the motherboard between the hinge and the top edge of the keyboard.
Depending upon the model of the laptop there is a plastic panel which houses push buttons and indicator lights that is located between the top edge of the keyboard and the bottom of the LCD screen. There are screws at the bottom of the laptop and possible screws on the back next to the hinge securing this panel. This panel would also have small plastic retaining clips locking it into place. You need a thin blade to lift this panel up, be careful not to crack the panel.
Once you remove this panel you see this video connector and cable. the connector may also be held in place with a screw and plate.
Jun 03, 2009 | HP Compaq Business Notebook nx7000
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Erratic problem
need to have the vertical output IC pins resoldered.
Jun 13, 2008 | JVC AV-27730 27" TV
Panasonic GAOO TV
Do you have to tap on the left lower side (facing the T.V) are the lines thin and white?
Has the T.V. ever turned off by itself?
This set was made in Mexico and Panasonic have HAD problems with dirty solder joints, "dry solder joints" as thay are called, expand and "open" with heat and age. Thay can "fix themself's" when the set is allowed to cool down or if you tap the joint back together. That is untill the set gets hot again and the joint expands and.........you get the picture?
Try re soldering your power supply solder joints, you MUST desolder and clean joints!
Hope this helps, sorry about the delay never been on this site untill today!
See Ya from Waterloo, Ontario CANADA.
May 20, 2008 | Televison & Video
Panasonic CT-36G24A Horazontal Hold
  • your problem is in the vertical output section as you have already mentioned that compressed down to 3 inch
  • if is is some times then you will have to check
  • loose contact in electrolytic capacitor in vertical output section
  •  it will be dry or some print cut must be there.you solder it.
  • it is best thing to replace all electrolytic capacitors in vertical output stage.they are hardly two or three.
  • it is a common failure,& not a major problem.
  • as per location of the suspect is concern it in the section from where the wires are going to crt neck.
  • hope this will help
  • good luck
Oct 18, 2007 | Televison & Video
Thin pale Horizontal line
I tried this and it has worked temporarily by banging the monitor not great but it did work, no tech knowledge if there is any other advise please email.
Hiyama Monitor Model: Vision Master 17 (8617E Chassis)
Horizontal dark line across screen shadowing text or other complex display data - giving appearance of 3D grooves or just dark lines on light background - temp fix (few minutes) by banging monitor or jiggling the video cable (thats what threw me for a while)
Removed tube base board and ran over disc capacitors and other solder joints whether they looked dry or not. No re-occurence in 2 weeks of daily use. Seems to have fixed it. (Be prepared for a lot of metalwork and screw removal when opening one of these up - I still havn't figured out how to get the PSU/main board out of one !)
(John)
Aug 20, 2007 | Gateway FPD1975 19" LCD Monitor
Televison & Video Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
